bad gas mileage?
bad gas mileage
I have a 2010 lancer gts sportback that gets about 250 miles to a tank of gas ? is this normal i changed my plugs and oil on this car it has 87,000 miles on it ! is their anything else i need to change on here like maybe the ? can someone help with this thx
Bad gas mileage
I am experiencing the same problem too. On my 09 Lancer ES with 111,500 miles, I changed the oil & oil filter. Also cleaned my MAF sensor & cleaned the k&n typhoon air filter the same time as I did my oil change. Before doing so, I was averaging 420-460 MPG and afterwards, I am only getting 390! Which is a huge drop. I don’t know if anyone else is having the same problems. But I am thinking of putting in some sea foam, readjusting the air filter in case of leaks, and rebooting the car ECU by unplugging the battery for a bit. I’m currently running Gumout solution through my gas tank and still no progress in increasing my MPG. Will update soon.
4G63_Crazy
Jan 8, 2018 03:59 PM
TurboTJ
Feb 2, 2016 02:16 PM
