Somthings a leakin....i am scared
Old Aug 16, 2003 | 03:40 PM
jsfour's Avatar
Heh so I am tightening my front and back plates and I realize when I look under the car somthing looks like its leaking....I am tinking mabie its water right...but theres alot of water comming out in that case. I am scared cause it looks as it is comming off my tranny. I dont understand cause my car had only like 4.5k on it and its a 2003 why would it be doing this?
Old Aug 16, 2003 | 03:48 PM
ghostrider's Avatar
What color is it?
Old Aug 16, 2003 | 03:51 PM
Lancer 4 Me's Avatar
it's probably clear, since he said it looked like water
Old Aug 16, 2003 | 04:03 PM
RumbleCam's Avatar
It is water.
Its probably condensation from your ac i get it all the time. It drips behind the motor because it condenses on the cold fins of the evaporator before the air goes into the cab. there is a plate to catch it but when you move the car it sloshes over the sides. also if you raise the front of the car to do your oil it will drop anout a half a cup of water on the ground.
no worries.
Old Aug 17, 2003 | 12:52 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
It can either be the AC as mentioned above or the defroster. We noticed that my car driped water (condensation) after running the defroster in the morning. In both cases, the water drips just behind the engine. I wiped it with my finger to make sure, and it was definitely water in my case. Just to be safe, check your fluid levels, but you're probably fine.
Old Aug 17, 2003 | 04:09 AM
RumbleCam's Avatar
When you run the defroster it turns on the a/c.
Old Aug 17, 2003 | 09:49 AM
Moderator
Bomb Squad Unit #02
I actually did not know that. Makes sense now that you say that, but I never thought of it
Old Aug 17, 2003 | 11:21 AM
RumbleCam's Avatar
Cool. You must've took some time off there was a thread goin around for a while called "defogger turns on the a/c?"
or else maybe you arent a evom junkie like i am...
anyway heres the thread if you want it.
https://www.evolutionm.net/forums/sh...efroster+a%2Fc
Old Aug 17, 2003 | 11:26 AM
Moderator
Bomb Squad Unit #02
Oh I'm an Evom junky fo sho, I just spend waaaaay too much time in OT (about a 5:1 ratio of off topic to on topic posts )
Edit: I noticed the thread is in the Evo section. I don't visit there often, having an OZ, although as you just pointed out, there is useful info in there too. Great, now I have to take another hour of sleep off my daily routine to read more of the forums
Old Aug 17, 2003 | 05:07 PM
pickleknock's Avatar
woah, why does it turn on the a/c for the defrost?
Old Aug 17, 2003 | 05:28 PM
RumbleCam's Avatar
Because when you rum air over the cool evaporator fins it dries the air which defogs the windows way better than just blowing air on them. In my old pickup when it rains i have to have the heat on defrost full blast to just keep the windshield clear but all my other windows are foggy. In the oz they stay clear right to the back because of the driing effect of the ac.
bonus is the less humid it is in your car the longer everything will last: water is bad.
iluvmydsm
Jan 24, 2011 06:46 PM
Nankov
Lancer Aftermarket Forced Induction Tech
34
Jun 13, 2008 08:45 AM
blood89
Lancer Tranny/Drivetrain Tech
10
Jan 25, 2008 10:01 AM
haseeb
Dec 27, 2007 07:50 AM
yank1969
11
Jun 23, 2005 02:17 PM
