New Exhaust Problem
Old Oct 15, 2008 | 10:01 AM
Haddy's Avatar
Exclamation New Exhaust Problem
Hey yall,
I just put the Tsudo N1 Axleback Exhaust on my 09 GTS and right infront of the Rear Axle where the New exhaust attaches it is slightly rubbing against the axle (frame). is there anything I can put inbetween the Frame and the exhaust to keep it from rattleing?
Thanks.
Old Oct 15, 2008 | 10:16 AM
hadeswolf's Avatar
I don't know but I'm wondering how your liking the exhaust. I'm thinking about getting that one.
Old Oct 15, 2008 | 04:50 PM
Haddy's Avatar
I love it. its pretty simple to put on, the stock one was a b*&^h to get off. but it took me about 20 minutes total. It sounds great and has a nice deep tone. good for the cvt as well.
I just folded alot of alum. foil in a square and tucked it inbetween the frame and exhaust. works good too.
Old Oct 15, 2008 | 04:53 PM
wevo1985's Avatar
u can possibly use a piece of tire. its tick and wont burn much that far back on the exhaust.
Old Oct 16, 2008 | 09:14 AM
Haddy's Avatar
anyone else reccomend the tire idea?
Old Oct 16, 2008 | 09:19 AM
spumoni1984's Avatar
I've used intercooler hose connectors, no problems for me. Al foil is a good idea too.
Old Oct 16, 2008 | 09:46 AM
CamShaft's Avatar
i don't suggest tire or any rubber. The exhaust does get hot, even back there. Silicon would be ok (IE intercooler piping) I would recommend finding why its rubbing. The hangers on the muffler could have been slightly bent during shipping.
Old Oct 16, 2008 | 09:54 AM
evo_soul's Avatar
send it back if you can. an exhaust that doesnt fit then you can be sure its going to cause more problems
Old Oct 16, 2008 | 01:00 PM
Haddy's Avatar
it seems to be fine. it hangs fine but sometimes if im stopped at a light or something it will rattle a little bit and make the noise. the stock exhaust hangers hold it up a little up higher than it should. im working on a fix, im going to autozone and orileys to look around after formation. ill let yall know.
Old Oct 17, 2008 | 11:06 AM
Haddy's Avatar
i kept the al. foil on there. it molded perfectly because of the heat. then I took the al foil exhaust repair tape (2 bucks at o'rileys) and taped the al. foil in place. works great!
Old Oct 18, 2008 | 01:21 AM
CamShaft's Avatar
but its not the right fix. Don't backyard mechanic your new car, make it right. Unless you just don't care. I bet the hanger is a bit bent. Get a friend with some mechanical knowledge and I am sure he could figure out your problem within 10 mins.
Old Oct 20, 2008 | 11:17 AM
Haddy's Avatar
Good point. Ill get my friend and we will check it out completely.
Old Oct 20, 2008 | 04:08 PM
Anarchy08's Avatar
Haddy hit me up when you and your friend are gonna do this that way I can come and watch 2 ppl scrath thier heads. LOL Always fun to watch ppl from ft. knox work on new cars. Makes for great entertainment
Old Oct 20, 2008 | 04:24 PM
Haddy's Avatar
Haha thats great I sent you a PM dude check it out.
