Help with interior lights
Old Nov 2, 2008 | 06:59 PM
link62's Avatar
Exclamation Help with interior lights
Ok guys i need help big time for some reason my interior lights wont turn on when i turn my head lights on for example my gauge cluster doesnt turn on but the other lights like the srs and others do when i put the key in but not when the lights turn on so does the ac, radio, ash, and cigar lighter wont and the radio dims from green to hardly visible and the clock wont dim like it normally would so im not sure if theres a fuse blown or a short in the wiring any help would be apreciated thanks
Old Nov 3, 2008 | 05:19 AM
Jehuty's Avatar
Just check the fuse box. You know where it's at? MY cigarette light doesn't turn on either, and I changed the bulb. I really don't know what to do.
Old Nov 3, 2008 | 09:35 AM
Juan Martinez's Avatar
I would check the fuses under the dash and under the hood. I would check them all. Everytime I've had a problem like this, it was a fuse I wouldn't think is connected to some other device.
Old Nov 3, 2008 | 05:32 PM
link62's Avatar
ok yea i went and checked all the fuses under the hood and under the dash and had 2 of them that were bad so once i replaced them its now working fine
Old Nov 12, 2008 | 11:29 PM
FiReTRuCKoZ's Avatar
I've got the same issue, but when I checked all my fuses they all were fine...I don't get it...
Old Nov 14, 2008 | 12:04 AM
A good piece of information...a friend of mine told me my passenger side taillight was out, but I had brake lights. I checked the fuse before replacing the bulbs, and it just so happened to be the fuse. once I replaced that fuse, the gauge cluster and hvac panel lights came back on. very interesting.
Old Nov 14, 2008 | 07:30 AM
bcollinstex's Avatar
A fuse may looks ok by a visual inspection. Get a pack of fuses for a couple of bucks and swap them out anyway and let me know what happens.
Old Nov 14, 2008 | 10:05 AM
Jehuty's Avatar
Yes Bcollin is right, fuses are very easy to overlook on whether they are blown or not, this weekend I'm replacing all mine.
Old Nov 14, 2008 | 10:09 AM
4bangn's Avatar
just fixed mine, fuse 20 under the hood, my passenger side parking lights stopped working along with my interior lights, lighter, climate controls, etc, come to find out it was fuse 20 under the hood, work fine now
