Nooooo i need help!!!
Old Feb 3, 2009 | 12:00 PM
nawgee's Avatar
Is there anyway of removing the CEL long enough to pass a smog test LOL. long story its time for a smog test for me and i have that stupid cat problem with my car (i know there was a recall, exactly why i said long story short). please if you guys know of how can get around this please help....if not....sigh i guess im screwd =(
Old Feb 3, 2009 | 12:10 PM
4g94T's Avatar
prior to testing... unplug the battery's negative terminal. wait atleast 15-30 minutes. that will reset the ECU, therefore the CEL also
make sure the car is warmed up and in operating temperature when they check it. that way the warm up cat does not need to work. (which is what your recall is)
Old Feb 3, 2009 | 12:15 PM
Curt@MrLed's Avatar
Former Vendor
A autozone may reset it for you, or anyone with a scantool will.
Old Feb 3, 2009 | 01:55 PM
nawgee's Avatar
alright im going to try that! this is my first smog check, what happens if i fail??
Old Feb 3, 2009 | 02:19 PM
Jehuty's Avatar
you die
Old Feb 3, 2009 | 03:32 PM
darkmitsu's Avatar
If you fail you still have to pay, and have a month or so to get it fixed , and you can take it back to the same place for a recheck for free usually ...
Old Feb 3, 2009 | 06:05 PM
nawgee's Avatar
Originally Posted by Jehuty
you die
NOOOO are you serious!!!!!
tear* I'll never be able to go turbo now =(
Old Feb 3, 2009 | 06:08 PM
hattackk's Avatar
be careful , if your required to have ready statuses on all systems in order to pass, once you reset the CEL you reset the ready codes.
Old Feb 3, 2009 | 06:46 PM
cfdfireman1's Avatar
^^^^^^^^^^^^^^ + 100 you failed
Ready status must be set before you will pass, it takes several cycles of starting, warming up and running right before it sets.
Old Feb 4, 2009 | 10:01 AM
link62's Avatar
I had the same problem with the cat and i took it to mitsubishi service dept and they did the pcm re-flash and fixed the cat for free. Take it in as soon as possible cause it took a least a day for them to fix it.
What code do you have?
Old Feb 4, 2009 | 10:47 AM
nawgee's Avatar
how do i go about doing that?
as far as the cat goes...i already took it in for service. then the problem came back and now they said that theres nothing they can do since my car is over 100ks
Old Feb 4, 2009 | 10:12 PM
Juan Martinez's Avatar
I had the same problem. They claimed to fix it, they did mine at 108k miles. The problem came right back after 100 miles. I gave up and have since decided just to put aftermarket exhaust on it. As for you, your screwed. Just an idea. Would one or 2 of those Cel eliminator things you put in place between the exhaust and the o2 sensor help any?
Old Feb 9, 2009 | 01:49 PM
nawgee's Avatar
today is the BIG day....im going to go outside and unplug my battery for 15min....roughly how long do you think my ses light will be off???
Old Feb 10, 2009 | 06:59 AM
jusy drive it normally
for a few days and hope the light doesn't come on. Like I said
"Ready status must be set before you will pass, it takes several cycles of starting, warming up and running right before it sets."
Old Feb 12, 2009 | 02:36 AM
kronic420haze's Avatar
leave a twenty on the front seat when you get out maybe he will look the other way. i know i can find ways around it and inspection .
