Please Help Me Now!!!
Old Sep 22, 2003 | 07:09 PM
TG LanceR's Avatar
Unhappy !
Old Sep 22, 2003 | 07:22 PM
TG LanceR's Avatar
Old Sep 22, 2003 | 07:28 PM
ryancb's Avatar
try waiting more then 15 mins and also u check fuses etc?
HobieKopek's Avatar
Did you disconnect any harnesses in the process? That'd be an easy possibility. I wouldn't call something you caused a problem with the car though...if that were the case I'd hate the Lancer more than half the forums combined.
Also if you could take pics of your wiring that'd be hugely helpful...I don't suppose you're about to do that though.
Old Sep 23, 2003 | 04:34 AM
TG LanceR's Avatar
Old Sep 23, 2003 | 04:55 AM
TG LanceR's Avatar
Old Sep 23, 2003 | 05:41 AM
neilschelly's Avatar
You shouldn't have thrown anything away until you were done, but now that you have, you have to pay the price. Just go to Mitsubishi and buy whatever parts you need. They'd have to be downright stupid to believe it is a warranty issue bulb going out. Besides, warranties are for real problems, not ones you cause - just suck it up and buy the part.
-N
Old Sep 23, 2003 | 12:41 PM
TG LanceR's Avatar
Old Sep 23, 2003 | 12:48 PM
HobieKopek's Avatar
He's saying Mitsubishi shouldn't pay for something that wasn't their fault. Personally I believe he's absolutely correct. Good luck.
Old Sep 23, 2003 | 12:49 PM
jamie's Avatar
i hate when people mess something up then blame it on mitsu.you broke it you fix it.
Old Sep 23, 2003 | 01:01 PM
uranium9v's Avatar
Check all your harnesses...sounds like one isn't in all the way. I've taken that console apart so many time, and I once had my A/C not work after...and the harness wasn't snaped in all the way. Did you put resistors on the LED's or what? Run them off the battery or the wires that were running the stock ones...if so did you put in LED's that were the same current and voltage as the stock ones?
Old Sep 23, 2003 | 01:13 PM
SpeshalK's Avatar
not only is playin with stuff you nothin about not smart but also posting your plan over the internet that ur plannin on having mitsubishi fix somethin u broke.....companys dont make money by being dumb....
Old Sep 23, 2003 | 02:02 PM
TG LanceR's Avatar
yes I ran 3.7 volt LED's with a 100 ohm resistor connected to each, and it is possible I unclicked a harness . I will check later and post
