intake problems
Old Oct 5, 2003 | 04:19 PM
younggotti's Avatar
intake problems
i just install my new intake and i was wondering why does the "check engine soon" light pop up?? how can i get rid of that??
Old Oct 5, 2003 | 04:43 PM
Archangelite's Avatar
disconnect the negative and then reconnect it about 10 mins later and start your car. leave the car idle for nothin less then 15 mins. then your car should be set. , and a little off subject, but i do this all the time and about 3 or 6 days later the check engine lite goes on. i dont know if its becaus the intake filter is dirty or maybe its not even the intake?
Old Oct 5, 2003 | 04:45 PM
younggotti's Avatar
thanks for replying back
Old Oct 5, 2003 | 08:59 PM
majestic lancer's Avatar
maybe something is wrong with your MAS sensor.. is the intake the only mod you have?
Old Oct 5, 2003 | 10:17 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
yeah if it was just the intake, the check engine light should not have went on. If you reset it and it comes back on again soon, check to make sure you didn't damage the MAS or leave something (vacuum hose or wire) disconnected from the install.
Old Oct 5, 2003 | 11:39 PM
nope everything is connected right, no hoses missing, the breather tube is connected. i do have a magnaflow catback. but everytime i restart the system, the light is off then 4 days later it goes on, but my driving is still the same, i feel no problems
Old Oct 6, 2003 | 11:15 PM
Moderator
Bomb Squad Unit #02
you should get the cel read at a dealer. It could be a problem not related to your intake. Are your cats still there? That's the only other thing I can think of that would set the cel off.
Old Oct 7, 2003 | 06:02 AM
one of the cats is there, the one closest to the trans. i guess ill figure it out someday....
Old Oct 7, 2003 | 06:05 AM
Bitnode's Avatar
i'd bring it to the dealer and have it checked.
Old Oct 7, 2003 | 12:40 PM
Moderator
Bomb Squad Unit #02
if there's only one cat, maybe you're mising a sensor reading from it, which would make the ecu think the cat is blown out.
Old Oct 20, 2003 | 11:06 AM
Gen4Racing's Avatar
take it to autozone, they will pull the codes for free
Old Oct 20, 2003 | 11:19 AM
Sailorgoon's Avatar
The second cat has an o2 sensor in it. If you want to get rid of that cat, get the RRM test pipe, as it has a threaded hole for the sensor.
Otherwise, you need to get the old sensor welded into the new cat replacement. You're probably running very rich. It will certainly throw a CEL without the o2 sensor.
Old Oct 20, 2003 | 01:40 PM
MaDLiB's Avatar
lazy *** autozone people here said they dont do it anymore!
screw you autozone!
Camrymatic
Aug 26, 2014 08:45 PM
CrackerJackToy
Jan 30, 2008 09:27 PM
herbal77
Oct 23, 2004 09:13 AM
jsfour
Jul 11, 2003 11:47 AM
Zopo
Lancer Engine Tech
33
Oct 23, 2002 06:21 PM
