Lancer doesn't start sometimes
Old Jul 2, 2009 | 01:33 AM
Lucas03ES's Avatar
Sometimes when I shut my lancer off for about 20 minutes and go to start it back up, it doesn't start. I turn the key, all the lights turn on and all I hear under the hood is one click. I can try it like 15 times and it won't work and then try it again and the car starts up fine without hesitation. Also, when the car will not start, when I use the remote start for my car, it starts right up. Any ideas? thanks
Old Jul 2, 2009 | 07:47 AM
senate6268's Avatar
Check the terminal connections on your starter real good. Might have some corrosion on them.
Old Jul 2, 2009 | 10:59 AM
03lances's Avatar
+1^ also check your battery connections and your main grounds that go to your motor and body, I would put money on connection issue
Old Jul 2, 2009 | 11:43 AM
Lucas03ES's Avatar
Does anyone have a diagram of the starter so I know where to check for corrosion? It's kinda hard to stick my hand back there and find every spot it could be.
Old Jul 2, 2009 | 12:07 PM
senate6268's Avatar
Better if you just remove your starter. It will make it easier to clean the terminals. Use some anti-corrosion spray on the connections after also.
Old Jul 8, 2009 | 09:17 AM
blaze_125's Avatar
You just gotta look at where the power/ground cables are located.
Also make sure the nuts holding down the cables are on tight.
Old Jul 8, 2009 | 09:20 AM
03lances's Avatar
And not rusted too, I worked on a car about 2 months ago they let it sit for over a year not knowing why it wouldnt turn over. Well after testing the starter and cleaning it all up it turned out one rusty nut that held the ground wire on the starter caused the whole thing!!! They didnt even have to buy a new nut I just wire wheeled it lol
Old Jul 17, 2009 | 09:49 AM
Lucas03ES's Avatar
Alright what would be the easiest way to pull it out? I am going to try and tackle my problem this weekend. Is there any way to test it when it is pulled out?
Old Jul 17, 2009 | 10:23 PM
Lucas03ES's Avatar
anybody?
Old Jul 18, 2009 | 12:01 AM
03lances's Avatar
Send me your email address I can send you something that should help you alot
Old Jul 18, 2009 | 04:55 PM
Lucas03ES's Avatar
Lucas89005@yahoo.com
Old Jul 18, 2009 | 08:53 PM
03lances's Avatar
email sent
Old Jul 19, 2009 | 03:53 PM
Lucas03ES's Avatar
Thank you man that helps a ton!
danfalcas
Mar 3, 2015 12:08 PM
Tibbar
Dec 2, 2013 05:14 PM
SaiKyo
Dec 4, 2012 08:12 PM
yenny
AEM EMS
Oct 7, 2012 02:24 PM
m0nkie
Sep 4, 2009 10:31 AM
