Evo 7 (Yet Another) Won't Start
Old Jan 30, 2015 | 01:21 PM
danfalcas's Avatar
My Evo have new battery everything is fine.
But sometimes when I arrive to a place an turn off my car when I try to start it after a few minutes it just wont start. Doesn't crank or anything but you can hear it is trying to
I will check:
-Starter Ground cable
-Battery connectors
I don't know, after waiting a couple minutes it starts normally
PLZ HELP
Old Jan 30, 2015 | 01:26 PM
LetsGetThisDone's Avatar
When it happens, try banging on the starter (with something heavy, rock , hammer, etc) if you can reach it. Sounds like the starter is getting stuck.
Old Jan 30, 2015 | 01:37 PM
danfalcas's Avatar
Thanks, also tried this and no, the starter is fine (BTW it is pretty uncomfortable this thing)
I had this issue on my Old car, it was the Main Relay but I don't know with the Evo
Old Feb 7, 2015 | 12:39 PM
danfalcas's Avatar
I checked everything but car if I turn it off won't start if I try within 5-10 minutes.
After that time it starts
Old Feb 9, 2015 | 11:14 AM
danfalcas's Avatar
No one?
Old Feb 18, 2015 | 08:36 PM
Brandonm's Avatar
Originally Posted by danfalcas
No one?
possibly a temp sensor? i had a bmw with a similar problem. It would not start after shutting it off.
Old Feb 19, 2015 | 12:06 AM
flippymcbean's Avatar
This might sound dumb, but check the wire on top of the starter with the black plug. And check the wiring for that as well. My wire was some how cut from the previous owner and I would have very similar symptoms.
Old Feb 19, 2015 | 06:26 AM
dyang9000's Avatar
Could be a loose connection on your negative or positive lead connection from your battery. I assume that when you turn the key to the secondary position that the radio and internal electronics light up? If so, it does not sound like a starter issue but a loose connections to the battery lead.
Old Feb 19, 2015 | 10:24 AM
danfalcas's Avatar
Thanks, after many TS with my dad (my mechanic) we found some diagrams of the starting system. The Evo does not have a starter relay it's a direct conection, so what we think it is , is the carbon parts inside the key thing (i dont remember the name).
I need to replace this part but i cannot remember how its called but is at the back of the key module (In the figure i think it's #7)
To bring you up to date, we did a complete test of current and everything is well connected. It's not the turbo timer, the starter is fine al cables on the battery are tight and everything.
The issue happens randomly.
Thanks
Old Feb 19, 2015 | 10:25 AM
danfalcas's Avatar
Al ready tried but Will do again to be triple sure! Thx
Old Feb 19, 2015 | 12:32 PM
zebra4's Avatar
Ignition switch. Exact same thing happened to my fiance's lancer.
Old Feb 20, 2015 | 08:39 AM
danfalcas's Avatar
Exactly, is that how is called?
This is what I need to replace
Old Mar 3, 2015 | 12:08 PM
danfalcas's Avatar
So the result is that it was the negative from the starter loose.
Wmu240
Dec 18, 2015 10:18 AM
Wmu240
Sep 4, 2015 07:02 PM
HugePwnr
Apr 27, 2014 07:52 AM
minstmeat
Apr 7, 2014 10:44 AM
dsevo
AEM EMS
32
Mar 22, 2008 08:11 PM
