whats the BEST way to clean a transmission
hey well i have my motor and trans apart.. and wanted to get it cleaned up before i put it back in. Main reason being that it got covered in axle grease when my boots ripped plus the normal dirt that gets on it. i tried the best i could with simple green/ some random degreaser and brake cleaner.. still looks nasty
what do u guys recommend would work good? any special steps to be taken/ how tos?
Thanks
BEFORE
AFTER
Thanks
BEFORE
AFTER
thanks guys ima them all ahaha.. just got the engine bay painted and dont want to kill it with a ugly trans since i have the chance to clean it now that its off
I would not use a wire brush.... either media blast it and paint, as mentioned previously, or use a nylon brush and simple green. Also, make sure you remove the TOB before you start spraying degreaser in there, cover any breather holes, and electronic ports with baggies and rubber bands before you start. Also, make sure that after you are done, you re-lubricate the input shaft, tob, fork before you slide everything back together.
contaminated transmission
I'm rebuilding an engine my transmission was covered but it must the ripped. Its a5 speed manual transmission and a little water got into it. Just seeing what's the best way or what can I put in it to flush all that crap out. I open up the drain and filled it with transmission fluid and let it run through it but is there any other way. Thanks
Darkn3s
Jan 25, 2011 12:21 PM
