80 miles already at half tank?!
Old Oct 18, 2003 | 07:46 PM
pjal84's Avatar
Originally posted by .L.
i'm running bone stock right now, and i get sucky gas mileage as well. what i've noticed is that our cars need a good amount of gas to get moving. you have to give our little sohc engines gas in order to move the 4 doors
Any 4 banger needs to wind up off the line to get moving, just the nature of it .
Old Oct 18, 2003 | 07:54 PM
nasdale's Avatar
My mileage went up after installing a SRI and axle back exhaust
Old Oct 18, 2003 | 10:59 PM
Lancer408's Avatar
i have SRI and axle back exhaoust and i barely get 285 if i it if i dont drive too hard.
Old Oct 19, 2003 | 10:48 AM
mxpx5678's Avatar
Yeah i dont know what you guys are doing either i have a pure stock 2003 lancer OZ and i drive around a lot in the city and out and i usually get at least 330 per tank which is about 10 gallons before i fill it up. I hope installing a SRI and Axle Back exhaust dont decrease that because i like getting 33 mpg
Old Oct 19, 2003 | 11:06 AM
pisetup's Avatar
I have a SRI, test pipe, and a straight back exhaust. My car eats gas like it's the end of the world.
Old Oct 19, 2003 | 11:19 AM
psionic98's Avatar
I only have sri and I barely get 280 per tank.. even without any hard driving (which was hard to try!!) On avg with some hard driving some highway, I get about 70-75 miles per tick after I had my sri installed, before sri I was getting 75-80 per tick... so for some reason lancers suck!
Old Oct 19, 2003 | 11:27 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Yes intake should improve gas mileage, which it did slightly for me (but my CEL didn't come on either). I'm still trying to figure out why my mileage didn't go up after getting the ecu reflash. Maybe because the test drive right after went up to redline multiple times, it programmed the ecu for much more aggressive driving? I thought it would relearn in 10 min when I drive regularly. I did notice a large improvement on mileage when I got my brake pads to stop rubbing.
Old Oct 20, 2003 | 09:56 AM
HobieKopek's Avatar
That's worse than MY gas mileage. That's sayin' something.
It's probably the MAS malfunctioning in some way, shape or form. There's no other reason aside from damage to the ECU that should cause you to flow that much fuel. Either that or you drive between redline and fuel cut everywhere you go.
Old Oct 20, 2003 | 05:43 PM
ghostrider's Avatar
I thought that if you get a CEL it automatically throws the ECU into a closed-loop and starts running ultra-rich to protect itself. That is the easiest explanation as to why your mileage is so bad. Hell, stomping around town I get 75 miles at the first tick mark.
jake33
11
Apr 16, 2015 05:22 PM
stevenmalone
Apr 20, 2014 07:15 PM
opusman
Feb 20, 2014 10:51 PM
