noise in the rear of the car too!
Old Oct 19, 2003 | 04:34 PM
majestic lancer's Avatar
Angry noise in the rear of the car too!
i have a noise coming from the rear of the car but its nowhere near squeaking. its like somewhat of a clunking sound like you're going over something on the road, but you're really not. it ONLY happens while im acclerating, not when im going over bumps. so say im at a full stop, the light turns green and i go.. its when im accelerating from a full stop till about 10mph that i hear a couple clunking sounds. its not a continuous sound nor is it there everytime.. its just an 'occasional' sound and i only hear it about 1-3 times while im accelerating. i dont think its my perches because i dont hear it while im going over bumps..
SECOND PROBLEM.. i had mitsubishi change my brakes about 1000 miles ago and up to this day, my brake pedal still pulsates when im braking at high speeds.. anyone have this happen to them too?
damn ****ty *** mitsubishi.. i hate them.. and on the side note, not only are they crappy, but they moved their service facilities from 1.5 miles away from me to 35 miles away from me.. whats up with that?!? damn, i might as well just trade in my car for a 350z.. again, any input would be appreciated.. thanks
Old Oct 19, 2003 | 04:57 PM
neilschelly's Avatar
The brakes pulsating might mean that you're rotors need to be turned, resurfaced. At least, that's my guess. If they weren't properly bedded in, then the rotor surfaces may not be smooth.
The noise is a tough one though - is it every time you go by 10MPH and will it keep going if you keep the speed steadily at 10MPH or will it just happen for a few seconds and stop?
-N
Old Oct 19, 2003 | 06:28 PM
it'll just happen a few times and then stop.. its not constant if i hold a continuous, slow speed.. it just comes and then goes..
Old Oct 19, 2003 | 06:41 PM
illizit's Avatar
maybe its something in your trunk rolling around? like maybe a tool mitsu left behind..i dont know it happened to me before! sorry couldn't help much..
Old Oct 19, 2003 | 06:59 PM
i highly doubt its a tool because there's nothing on the surface of my trunk.. and underneath the mat, where the spare tire is, its just my spare and the jack.. nothing else.. so i doubt its something there..
Old Oct 19, 2003 | 07:21 PM
twardnw's Avatar
When is the noise in relation to when you shift? Is the weight of the car shifting when it makes the noise? And as for being a whole 35 miles from the service peeps, I'm closer to 60 miles.
Old Oct 19, 2003 | 07:27 PM
the noise is not relevant to when the car shifts.. it just comes when im accelerating from a dead stop and then it disappears.. HOWEVER, i forgot to mention that i dont hear the noises at all when i gun it from a stop.. its only when im acclerating slow when i hear it.. and as for the weight shift, its not due to that.. my cd's shift in my center compartment due to the weight shift, but not this noise im hearing.. and since you drive 60 miles to service, at least it gives me some hope.. its just annoying coz i got used to driving 2 minutes for service.. i guess i jus gotta get used to it..
Old Oct 19, 2003 | 07:33 PM
fkrzo's Avatar
I just looked at your registry, I have the same problem, Its your exhaust. Only happens once in a while, 1 or 2 quick bangs, thats it.
Old Oct 19, 2003 | 07:34 PM
bobaab's Avatar
well in your spare tire compartment, you have that wrench to use with the jack..that could be shifting around..but it sounds like you checked that already..
Old Oct 19, 2003 | 07:38 PM
EXACTLY!!!! is it normal? or should i have it looked at? and what causes it?
Old Oct 19, 2003 | 07:45 PM
fkrzo's Avatar
The hangers aren't stiff enough. It doesn't bother me to much. It doesn't happen with a stock exhaust because its to small. It shouldn't cause any problems.
Old Oct 19, 2003 | 07:51 PM
oh ok.. wow.. i gotta admit i was getting really annoyed bcoz i didnt know what the hell it was.. i even crawled under the car to check my damn perches! since its nothing to worry about, thats a big 'whew!'.. now back to my brakes.. anyone have any input on that? oh yea, thanks again fkrzo
Old Oct 19, 2003 | 07:56 PM
akinaspeedstars's Avatar
if ur brakes are makin ur noise then well its gotta be that u got eibach springs right? i had that same damn problem i took it to mitsu and it finally stopped they installed the springs wrong and changed the drum all the brakes and the rest of the stuff take it in trust me
Old Oct 19, 2003 | 07:57 PM
nah its not my brakes making the noise.. its just that my brake pedal pulsates when i brake at high speeds.. no noise at all.. it was squeaking before, but i changed it before i warped my rotors..
Old Oct 19, 2003 | 08:05 PM
MrKentChu's Avatar
pedal pulsation
when ur brake pedal pulsates when u step on the brakes, it's most likely your rear rotors that are warped. when front rotors warp you'll notice it more in the vibration of your steering wheel. as far as the noise in the back goes, get someone to drive your car while u grope around the back.
kent
