Engine hesitations
Old Jan 31, 2010 | 09:33 PM
cajjj34's Avatar
Engine hesitations
Never had a problem until about a month ago, I ran a lucas oil fuel cleaner through my 02 lancer. I changed out plugs and wires 2 months ago along with the oil. Any ideas? Thinking fuel filter/bad injector?? Service light on but have a header with no eliminator on exhaust and 56k miles. Help me Gurus!!!
Old Jan 31, 2010 | 09:35 PM
cajjj34's Avatar
I also bought a MAS flow cleaner???? Waste?
Old Feb 1, 2010 | 10:49 AM
cajjj34's Avatar
Anyone have any ideas???????
Old Feb 1, 2010 | 11:30 AM
ambystom01's Avatar
Clean the MAF and see what happens.
Old Feb 1, 2010 | 04:26 PM
senate6268's Avatar
Do you know what code(s) the CEL is for?
Old Feb 1, 2010 | 08:02 PM
cajjj34's Avatar
No i think because I have the header and CAI on there the light comes on no eliminator. Going to clean the MAF and CAI filter. Fingers crossed and other suggestions?
Old Feb 1, 2010 | 09:02 PM
JRR's Avatar
JRR
what brand and heat range plugs did you put in? not saying that it might be an issue but just wondering.
josh
Old Feb 2, 2010 | 08:05 PM
cajjj34's Avatar
Whatever the auto part store called for I believe bosch platium, I also replaced the wires (coil packs). But ran fine the last couple weeks, then ran a fuel cleaner through and all the sudden almost like its mis-firing, runs fine for a while or at higher rpms. Doesnt matter what gear mostly from 2nd to 3rd it seems........Any other suggestions???
Old Feb 2, 2010 | 08:06 PM
cajjj34's Avatar
bad plug, wire, injector, or something else???????
Old Feb 2, 2010 | 08:12 PM
JRR's Avatar
JRR
what brand wires? i personally dont like bosch at all the only thing i will run on my car is ngk's.what did the plugs look like when you pulled the old ones out? that could also tell you something of whats going on.
if you know anyone with a tactrix cable and evo scan in the area try to data log it and see if anything is out of the norm. i could help but i live just north of madison.
josh
Old Feb 2, 2010 | 08:23 PM
cajjj34's Avatar
I had denso iridium plugs in there one looked at little burnt, but nothing bad on the wires. Wire brand I have no idea whatever they sell at the store.
Old Feb 2, 2010 | 10:19 PM
JRR's Avatar
JRR
did the plugs have any straight up and down lines on them? if so you had a misfire. were the tips of the plugs discolored at all? what store did you get the wires from.
only reason im asking is that i work at an auto parts store and i like to know how our competition holds up.
josh
Old Feb 3, 2010 | 12:46 AM
03lances's Avatar
I would get that cel checked just to be sure autozone will pull it free. If it is just for your 02 if not then you have something to go on.
Old Feb 4, 2010 | 02:36 PM
cajjj34's Avatar
I will do that and update after all is covered.
