Dumba@@!!! Drove threw high water!!!
Old Jul 28, 2010 | 05:26 PM
03lances's Avatar
Originally Posted by brokeazzlos
Dumbazz! Your engine sucked in water and hydrolocked.
Nothing to do.with the starter. Pull your plugs out and tuen your engine over to get the water out. If it doesnt turn over, you probably bent the rods and the engine is toast. Gl dumbazz
^^ This is what you need to do first before anything. Start from here then post the result here so we can help you.
Old Aug 1, 2010 | 07:01 AM
mcgarvey's Avatar
Since we've heard nothing from the OP I'm guessing he already found out that it needs a motor and either has it in the shop or ditched the car. You live and you learn I guess. I've seen enough hydrolocked engines come into my shop that I'm paranoid about even driving through big puddles, and I would NEVER run a cold air intake.
Old Aug 2, 2010 | 11:59 AM
jwick76's Avatar
this is why i installed a bypass valve. saved my azz two weeks ago. so many ricers on the side of the road with hazards on hydrolocked from sucking it right up through the bumper filter. *shakes head*
Learned this from my friend Jeff who invested $18k into his honda civic setup only to trash it in a deep puddle.
Old Aug 5, 2010 | 10:11 PM
02-Lancer-Es's Avatar
Bent a rod
The Clunk when you tried to start it was it hydrolocking .
Old May 20, 2011 | 01:28 PM
superk1980's Avatar
Update? almost a year later
fjm9898
Jun 20, 2016 10:12 AM
SnowtaEvo
Oct 30, 2015 08:44 AM
ptm5070
12
Jan 9, 2014 12:19 PM
danmark
10
Dec 31, 2012 10:17 AM
STIslayer
Feb 2, 2007 10:36 PM
