Odd noise?
Old Sep 5, 2010 | 03:42 PM
itz_speld_rong's Avatar
Odd noise?
So when I turn my steering wheel, there's a creaking sound. It only seems to creak at certain points on the turn and it sounds like something in the cab more than out by the wheels themselves. I already checked the power steering fluid levels and everything is fine there. Any ideas/suggestions? Thanks guys.
Old Sep 5, 2010 | 08:42 PM
mci2727's Avatar
Ball joint?
Sounds like it to me.
Old Sep 6, 2010 | 10:29 AM
How would I go about checking if that's the problem?
Old Sep 6, 2010 | 11:06 AM
evilempire18's Avatar
might have to take it to a shop and have the front end greased but before you do, spray some lube on the sway bar fame bushings and see if the noise goes away.
Old Sep 6, 2010 | 06:57 PM
Thank you sir.
Old Sep 8, 2010 | 12:17 PM
Danno's Avatar
I would check the strut mounts. I had the exact problem.
I found that at the time (2005) it was cheaper to put in coilovers than to replace 2 strut mounts.
Old Sep 9, 2010 | 09:05 PM
HornstarBU's Avatar
Well dang, I want coilovers but just can't afford it right now. by cheaper, how much were coilovers in 05? I see around 900 now for megans or tein as pretty much the cheapest. My cheap solution is probably going to be KYB ones....oem replacements are for losers like me i guess
on topic though, was that the sound, and spraying some wd40 on it made it go away, or no?
Old Sep 10, 2010 | 04:19 AM
mci2727's Avatar
Nevermind
Old Sep 10, 2010 | 09:51 AM
The sound even happens when I'm not moving and I turn the wheels. (I'm not sure if that information helps narrow it down at all)
I'll go try lubing the sway bar fame bushings and let you guys know if the noise disappears.
Old Oct 9, 2010 | 06:37 PM
my-lancer's Avatar
check ur outer tie rods.
Elvis
Lancer Troubleshooting
22
Apr 23, 2018 03:51 PM
Subierag
Apr 23, 2018 02:59 PM
subrwho
19
Jun 1, 2013 11:36 PM
eric6
Jul 22, 2012 11:02 AM
IS2000
May 7, 2011 10:39 PM
