Left front wheel issue
Old Sep 21, 2010 | 09:35 PM
Lancer XI1's Avatar
So every time I get on the gas or start out kinda slow (almost to the point stalling) the wheel makes a crack noise or clicking. At first it was just doing it when i got on it, now its cracking when I turn. What can this be??
Old Sep 21, 2010 | 10:42 PM
JRR's Avatar
JRR
replace the cv axle now or you will be buying a new front wheel bearing and probably some other things as well. thats usually the cause. i ignored one on mine and it cost me $1500 to replace! unfortunatley all done at the dealer so shop labor rate is super high....
Old Oct 27, 2010 | 08:52 PM
hotrod11686's Avatar
I got this too, should I do it to both sides ??
Old Nov 25, 2010 | 05:48 PM
Calicab's Avatar
check the boots for tears and make sure they are intact and attached well to the cv joint.
as for the bearing, jack the car up and tilt the toe of the tire in and out same with camber. if there is excessive play this means you have a bearing going.
to shoe heel toe and camber....look at the right side of the pic
eXtreme-Speed
Aug 7, 2016 06:14 AM
Luminox
Sep 2, 2014 03:03 AM
Thomar
Apr 27, 2014 07:10 PM
Grimgrak
May 27, 2013 10:34 AM
antiworldinc
Mar 16, 2006 03:16 PM
