Electrical Problem
Old Nov 24, 2010 | 02:29 PM
lp31990's Avatar
Electrical Problem
A few weeks ago i replaced my battery and alternator from Autozone due to my car not starting. I finally got it running but it went back to what it was doing before. My windows take FOREVER to roll up, my lights dim while idling and when my dash lights are on my gear shift lights aren't on and vice versa. Also the light in AC gauges just shut off. I currently drive a 03 lancer oz. Do you guys know where i can take to get this fixed or where i can fix it myself? Thanks
Old Nov 24, 2010 | 02:45 PM
03lances's Avatar
Do you have any kind or multimeter or voltmeter? You could have bad loose or disconnected grounds somewhere or the alternator you got could be a dud. If you can measure volts the car should be around 14v when running. If its higher or lower then you have a problem with the new alternator.
Old Nov 24, 2010 | 02:55 PM
mci2727's Avatar
For sure check the volts and connections like 03lances said.
Also could be dirty connetion at battery.
Old Nov 24, 2010 | 04:00 PM
Photool's Avatar
Definitely sounds like a short.
Has your lancer been exposed to any excessive amount of water in the engine bay ?
Old Nov 25, 2010 | 09:53 AM
lp31990's Avatar
No it is exposed to the elements bc i live in the barracks in TX. How would i test the voltage? Just turn the car on and connect it to the battery posts (+ & -)?
Old Nov 25, 2010 | 01:43 PM
mci2727's Avatar
Yep, just get a DC voltmeter and check the power at the battery.
Should be above 13.5v when running.
Old Nov 26, 2010 | 12:16 PM
Photool's Avatar
Old Nov 30, 2010 | 09:26 AM
PGDlancer's Avatar
^^ these guys clearly know a lot about it
I found out that my B+ fuse was hanging by a thread and basically dead (the yellow 60A fuse that connects the battery to the under the hood fuse box ). Might be a long shot, but it took me forever to figure it out.....
Fox5.56
Apr 18, 2017 05:13 PM
evo82005!
Oct 13, 2015 07:21 AM
Time To Shine
Apr 19, 2013 07:15 PM
gridiron44
Jun 5, 2010 10:30 PM
tom-oz773
May 5, 2008 06:23 PM
