Misfire?
Old Dec 22, 2010 | 01:54 PM
nawgee's Avatar
Misfire?
Hey guys!
I am having a problem with my 03 Lancer. Whenever I start the car, it feels like it misfires and the car jerks as I slowly accelerate. The only time I feel the jerking (or misfire) is when the car is idle. A few years back I had a problem with misfires due to my coil pack. Also when I check for codes nothing shows up as a problem, so I am REALLY confused as to what to do here.
My question is, what should I do to diagnose a car that seems to be misfiring. A friend of mines said that it could be due to bad spark plug wires, but how do I know if my spark plug wires are bad?
Thanks
Old Dec 22, 2010 | 02:10 PM
evo 9 guy's Avatar
Do you have a spark tester? (Really the only way to visually test for spark)
http://www.autozone.com/autozone/acc...er=900800_0_0_
Old Dec 23, 2010 | 11:39 PM
nawgee's Avatar
okay i'll try and pick one up tomorrow. i am assuming this would also tell me if my wires are bad right?
Old Dec 24, 2010 | 12:54 PM
evo 9 guy's Avatar
Well if you do not have any spark it will not light up and at that time you can start at the wires, but unless something happened it is not common for wires to just go out randomly.
Old Dec 27, 2010 | 06:41 PM
03lances's Avatar
If you have a multimeter (you can get a cheap one for under $20 that works fine) you can test the ohm resistance of the wires. Max is 19k, anything over that is bad wires.
mrhussain
24
Feb 16, 2017 08:01 AM
Boss777
Dec 1, 2013 09:16 AM
Arkitek
18
Jun 27, 2010 06:53 AM
NYREDEVO
Nov 13, 2008 06:04 PM
bboy_RES
Jun 7, 2008 02:21 AM
