AC is stuck on!!!!!
Old Mar 30, 2011 | 10:17 PM
larlo's Avatar
AC is stuck on!!!!!
Hi everyone.
I have a 2002 Lancer LS. It's currently sitting at 118,000 miles. Good little car. It was my wife's first car and it has served us well. However the weirdest thing happened this morning before my commute.
I climb in and start the car. I see the AC light is on. I think I might have hit the button last night and push it to turn it off. It stays on. I try again. No luck.
I am plagued by the same sticky heat control/broken knob ( it snapped off last March). I have it push all the way over to hot. It was just as warm as it always is on the morning drive. I'm just wondering if anyone else has had this problem and if it's connected to the stuck heater controls?
Old Mar 30, 2011 | 11:26 PM
03lances's Avatar
I had this happen to me once, I had to pull the bezel off then unscrew the two screws that hold those 3 buttons on and hit the rubber "underbutton" (I guess I could call it that) for the A/C to turn it back off
Old Apr 25, 2011 | 09:38 PM
ThaKing's Avatar
My Lancer had the same problem. Never really fixed it, but found that if I turned the A/C, heat nob to hot, then cold, then back to hot, that the A/C light would go off. Have you figured anything else out on this.
Old Oct 1, 2011 | 09:56 AM
phi79's Avatar
Have you got this fix? I just have the same problem now and I did what 03lances mention but still stuck on.
Old Oct 7, 2011 | 09:06 PM
sneaky_pete's Avatar
It could be one of the pressure cycling swithes or maybe the control itself shorted out.
Old Oct 11, 2011 | 12:40 AM
mitsuozboi's Avatar
Mine broke as well. And my AC light is also stuck on. I have to reach under the dash and move the heat control by hand to adjust temp. Ill probably try taking the HVAC out and seeing if maybe its just a stuck button or something. Dam mitsu.
Old Oct 11, 2011 | 10:39 AM
fritobandito24's Avatar
Okay, this probably isn't the cause, but maybe the knob is turned too far to the "Max A/C" option. It won't let you turn the A/C off if it's on that.
Old Oct 12, 2011 | 05:26 AM
phi79's Avatar
My is on hot now and still won't turn off.
Old Feb 11, 2012 | 11:46 PM
i.Apotheosis's Avatar
My knob is also stripped and broken off. I use the lever under the dash that is above the gas pedal to change the temperature, but what is weird is the green AC light is always on no matter what. It doesn't seem to matter because the heater still blows hot and the ac blows cold when I switch them back and forth to the extremes, but it is a pain and I wonder if I am losing gas milage by having the AC light on like is the AC unit actually running at any time other than at full cold?
Old Oct 16, 2013 | 05:32 PM
NatWu's Avatar
I have the same problem. I find that pushing the defrost button simultaneously with the AC button is the only way to get the AC to turn on or off. I don't know if it's a problem with the plastic button that actually hits the tiny switch on the circuit board or if it's the switch itself.
Old Oct 17, 2013 | 05:30 AM
03lances's Avatar
Its most likely just the plastic button making god contact. Easy way to find out is to take them off and try it.
Old Feb 25, 2017 | 06:32 PM
03nevaevolution's Avatar
Veteran: Army
Fixed
Hitting both the defrost and accidentally buttons simultaneously worked! Thx!!
Old Jun 23, 2019 | 04:08 PM
Fourdoor's Avatar
I will have to try this. Did a search in Ralliart General with no search results, and posted my own thread... glad I did a google search and found this thread!
Keith
Old Nov 17, 2021 | 11:40 AM
mr_mahoney's Avatar
Thank You ! Pressing the AC and Defrost buttons at the same time (a few times) and it worked !
What a crazy fix
Old Mar 4, 2025 | 02:41 PM
rmcghee's Avatar
Hi All,
My A/C and defrost buttons lights were staying on, too!
I disconnected the 12V battery to clean the terminals and, guess what?
Yeah, the A/C and defrost buttons now work correctly!
lemon_head
Nov 24, 2025 10:59 PM
Rom
Aug 18, 2017 12:44 PM
Kevin.
Jul 24, 2017 11:22 AM
inslowoutfast
Apr 21, 2017 06:19 AM
Jonno99
Aug 7, 2016 04:51 PM
