Headlight Problem
Old Apr 1, 2011 | 02:53 PM
lancerguy0208's Avatar
Headlight Problem
When I turn my headlights on one bulb comes on brighter than the other, ike the high beam is on. When I switch the stalk to turn on the high beams the bulb that was bright becomes dim and vice versa. I know its not a bulb problem because both bulbs work fine, but not at the same time. I'm thinking some sort of wiring issue, but how do I go about fixing it?
Old Apr 3, 2011 | 10:59 AM
03lances's Avatar
Very strange do you have after market headlights? It could be as simple as someone splicing the high and low beam wires opposite on accident.
Old Apr 25, 2011 | 09:41 PM
ThaKing's Avatar
Start by checking all of the wires themselves. Wires in cars over a period of time have a tendency to tear and rip the plastic around the wires. They may have a slight ground on them, or a wire could be simply switched out in the wiring itself.
Did it happen all at once, or has it been noticeable over a period of time, just getting worse?
DaEvoPusha
May 10, 2017 01:26 PM
richo17
Sep 5, 2016 08:22 AM
slatermvp
Dec 31, 2010 07:07 PM
PC325xi
Mar 4, 2008 08:44 PM
Kurt
14
Jul 31, 2007 12:14 AM
