ticking noise while heater or AC is on
Old Apr 21, 2011 | 06:39 AM
cali11b's Avatar
Like the title says i have aa annoying ticking noise anytime my heater or Ac is turned on. I had my blower motor replaced 2 days ago cuz the heater and AC stopped working completly. After it was replaced it worked like a champ but now i started getting a ticking noise on my way to work this morning Anyone have any clue what this could be? or how to fix it? thanks
Old Apr 21, 2011 | 10:17 AM
CamShaft's Avatar
I would pull the glove box and cabin air filter, then you can have a look at the blower motor and see if anything fell into it or what may be causing it.
Old Apr 27, 2011 | 07:35 AM
mshilto89's Avatar
Is it a constant ticking noise or just when you turn it on? If if only happens when you first turn it on and then maybe every other 30-45 seconds when the AC/Defrost mode is on the ticking noise you hear is the condenser/compressor kicking on to cool the air. If you notice when you hear the click it will cause the engine rpm to decrease or increase (depending on whether it is coming on or off) because it is using more power. You will def notice this if you are sitting idle.
Hassan
103
Aug 5, 2023 11:37 AM
Hector_villa
Lancer Troubleshooting
Nov 22, 2015 03:43 PM
TJSAP00
25
Dec 27, 2011 09:39 AM
blaze_125
22
May 4, 2009 09:45 PM
boostedwrx
May 22, 2006 04:22 PM
