cant take off sway bar end links
Old May 11, 2011 | 12:55 PM
erikerwin's Avatar
im installing my springs and cannot take off the sway bar end links off the strut assembly. torqued the nut but it keeps on spinning in the ball joint. any idea how to take it off?
Old May 13, 2011 | 08:55 AM
YeOldeLancer's Avatar
at the end of the Sway bar link, there is an allen key that you can use to keep it from spinning. Use lots of PB blaster or liquid wrench to loosen up any rust. if all else fails, usea vice grip wrench near the rubber boot. Mind you that this will most likely damage the boot and you'll have to replace the end link. They cost about $25 a piece.
Old May 13, 2011 | 09:02 AM
turbotime's Avatar
put a wrench on the nut, allen key in the endlink slot (in the middle o the nut)... hole the allen key firm as you twist the wrench to loosen the nut off..
easy as pie.
Old May 13, 2011 | 09:09 AM
erikerwin's Avatar
yea felt stupid i didnt see the allen key. now the problem is that I cant put the nut back on, it might have skipped a thread and is stuck. recommendations?
Old May 15, 2011 | 07:46 AM
Replace the end link. I did the same thing. Get if off of amazon. Moog.
Old May 16, 2011 | 09:16 AM
CamShaft's Avatar
use a die or thread chaser to fix the threads.
Old Oct 2, 2014 | 07:08 PM
Honni414's Avatar
I've tried everything in this thread, heated it with a torch, cut the "ball joint" side of the end link off and it's still stuck, HELP! This is my DD. I've even tried to hit it through with an air hammer now that it's cut off and no movement!
Old Oct 3, 2014 | 06:37 AM
CamShaft's Avatar
sending a picture would help. But, you will be able to get it out with a torch or zip disc. You have to get it red hot, although not recommended for suspension parts. Cutting it off with a zip disc would be your best option and buy new end links.
kaj
Jul 12, 2017 02:52 PM
eeweeks
May 25, 2016 09:21 AM
riceranger
Jul 26, 2009 09:16 PM
Vivid Racing
16
May 31, 2006 10:55 PM
Vivid Racing
Evo 'For Sale' Suspension / Brakes / Handling
Aug 24, 2004 09:47 AM
