Lancer starting problem
Old Jun 30, 2012 | 07:01 PM
flunsky83's Avatar
I just got done redoing the head gasket and timing on my 2003 Lancer es. Checked for interference and lined up the timing marks on the cam and crank. Change the spark plugs. When i try to start the car it seems like the timing is off or i am misfiring.What is going on?
Old Jul 1, 2012 | 09:34 AM
03lances's Avatar
Will it stay running at all? Forget to connect crank sensor?, Compression test? What was the exact cause of needing to do the head gasket in the first place? At any rate if it was me I would start by double checking EVERYTHING electrical is connected, maybe something slipped out. Next I would check for any blown fuses, if nothing comes up there then I would do a compression test.
Old Jul 1, 2012 | 03:37 PM
flunsky83's Avatar
I figured it out. The guy before be swapped the spark plug wires around. I fixed that it fired right up. Thanks
justme1
Aug 31, 2014 06:29 PM
BlackEvoV
Jan 5, 2014 11:13 AM
ATaylor
Nov 6, 2012 02:44 PM
charliep
Lancer Engine Tech
Jan 7, 2011 12:00 PM
Lucas03ES
Lancer Troubleshooting
12
Jul 19, 2009 03:53 PM
