Vibrations in acceleration/deceleration
Old Dec 12, 2012 | 07:14 AM
Grind3r's Avatar
Originally Posted by 02LancerRally
Where did you get yours from that's cheap lol
Napa.....Depending on if your an Automatic or manual, price will differ though. For some reason the rear mounts on the manuals are nearly twice the amount, but we all use the same front mount. $54 a piece if your Auto (front/back)...If your Manual the rear mounts run about $97
Old Dec 13, 2012 | 09:02 AM
02LancerRally's Avatar
Yeah I have a manual I got a quote from car quest for 54 for the rear mount and from O'Reilly auto parts for 87.00 for the same part
Old Dec 16, 2012 | 01:44 PM
"Update" replaced the bad mounts still have my vibe noise heres some videos
Old Dec 16, 2012 | 01:45 PM
and the second one
http://www.youtube.com/watch?v=vpzBZ...ature=youtu.be
Old Dec 25, 2012 | 12:30 PM
Dreamartist's Avatar
Update: I took my car in for an alignment (since it was time for one to begin with.) The vibrations were still there, though it only occurred during acceleration. I have a feeling its the transmission mount especially how the car engages into first gear. Let's see how this goes. I haven't had replaced the mounts since I got my car back in '01.
Old Dec 25, 2012 | 12:35 PM
02LancerRally- I the sound from the vibrations seem countinuous as long as your car is in motion. When it slows down, the sounds from the vibrations lessens. I wonder if it could be an alignment issue.
Old Dec 26, 2012 | 04:21 AM
Well it drives straight when I let go of the wheel and I have no vibe in the steering wheel so I don't know but I did notice when I was trying to go up the steep drive way it felt as if it was slipping?
Old Dec 28, 2012 | 02:22 AM
Blackstar37's Avatar
Check your axles. Go down there and shake the **** out of them(both sides). Had a similar problem with my oz and realized my driver side axle was out.
Old Dec 29, 2012 | 01:36 PM
eusgen's Avatar
^ Yes, check for play in the axle
Old Dec 30, 2012 | 04:57 AM
Have you checked to see if your tire is balanced? Maybe rim is bent?
Old Jan 3, 2013 | 02:24 PM
Well I switched the fronts with rears and nothing changed still got the vibes but nothing in the steering wheel also the drivers side CV has been replaced before no tears in the boots pass side I think maybe OEM but no visible damage
Old Jan 10, 2013 | 06:03 PM
tabrezk's Avatar
could be the balance shaft
Dross99_si
13
Sep 16, 2016 10:57 PM
meckert
Sep 9, 2016 09:53 PM
vassili
May 13, 2014 06:33 AM
CrAnSwIcK
35
Aug 15, 2013 09:58 PM
oak2207
10
Jan 28, 2008 10:20 AM
