2002 lancer OZ Rally cold start issue
Old Mar 5, 2013 | 10:11 AM
Slipknotjester's Avatar
Unhappy 2002 lancer OZ Rally cold start issue
Hey guys, I will jump right into the issue.
When I start my lancer while engin is cold, I have to stay on the throttle untill it warms up or it bogs down and usually dies imidiatly.
But here is the weird part...
I can adjust the curb idle screw (on top of the throttle body) to where it will idle at 750RPMs at cold. Once it warms up, the idle speed also Increases to about 1500 - 1750.
Back story.
I have replaced my; idle air control valve and motor(IACV), throttle possition sensor(TPS), and plugs and wires.
I am still throwing codes; PO301 and PO507.
Old Mar 5, 2013 | 11:04 AM
Green_Bandit's Avatar
Cylinder 1 misfire & P0507 - Idle Air Control System RPM Higher Than Expected
Old Mar 6, 2013 | 05:50 AM
Ace King's Avatar
Aside from the codes - when you start your car up, is your ac/heater on? if mine are on when i start them up sometimes my engine bogs down to the point where it seems it might shut off.
Old Mar 6, 2013 | 10:29 AM
CrazyBoyS's Avatar
Mine did this at one point but figured out that my thermostat was finished. Replaced it and haven't had any issues since.
Old Mar 7, 2013 | 09:27 AM
I do not have either on when I start. Also, a new issue has occurred. When I first start my car, the cruz control light turns on as well. (But my Cruz control does not work)
Old Sep 19, 2024 | 05:40 PM
Terry kale's Avatar
02 oz hard to start
turns over but wont start in the am. stop trying and try it again.. after 5 5o 10 times it idles very slow. letit warm up a little than it will rev up. used to hit the key in the am amd it fast odles... no more ?????????????????????
SunnyC
Apr 14, 2020 05:21 PM
moyassine
Mar 9, 2016 01:18 PM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
matrho2792
Aug 23, 2014 02:45 PM
ittick
Lancer Troubleshooting
Jul 16, 2013 08:58 PM
