Popping out of gear
Old Apr 3, 2013 | 04:44 PM
lancerodum's Avatar
Popping out of gear
Alright, so my 08 Gts 5spd was a rental up until I got it at 43k miles, I'm almost at 60k and having issues with the car staying in gear. 1st pops out from a stop and 2nd pops out as soon as I shift into it or the few times I have started in it to avoid first. I have been told it is all tranny, shift forks and bad synchros, have also been told it's a bad throwout bearing. Being a rental for so long I could see the clutch going from people beating it up, the rental company did the bare minimum maintenance, first tranny flush was done today... I used synchromesh as I was recommended by a mechanic friend. I saw a slight improvement, but nothing drastic, still pops out. No idea where the linkage is on this car so I haven't checked it. What could it be?? Any ideas or help would be appreciated!
Old Apr 3, 2013 | 07:27 PM
cfdfireman1's Avatar
not the clutch.
Old Apr 3, 2013 | 07:30 PM
joseph143's Avatar
Try cheapest easiest thing first... Shifter detents... They thread in from the outside and they are what lock the shift rail/fork in place... I'm sure shep or jack's would be happy to sell themto you... 20 minutes of work and it could fix your problem... Maybe 50 bucks tops... Or send it to a tranny ahop for a 900+ rebuild... Your choice
Old Apr 3, 2013 | 08:28 PM
lancerodum's Avatar
I have never heard of a shifter detent, but would definitely like to try that out. Where is that located/what has to come out to get to it? I know almost nothing about transmissions, or I would have pulled it apart already.
Old Apr 3, 2013 | 08:54 PM
joseph143's Avatar
I know nothing about 07+ lancers... But they are on the outside of the casing... Usually on the top. They look like a big *** bolt. On my 5spd its right bellow the trans mount
Old Apr 5, 2013 | 09:04 AM
joseph143's Avatar
Read the trans diagnotic procedure... It says the poppets or cables are bad... If you find the 3 bolts one the outside of the casing and pull em... You can swap them between themselves... Mive 1-2 to 3-4, 3-4 to 5-r and so on... The fault should follow it its the cause... That will give you a better idea...
Daitonsralliart
27
Aug 17, 2019 10:19 PM
azboost92
10
May 10, 2016 11:01 AM
Grimgrak
Mar 14, 2016 10:37 PM
MisterMR
14
Jul 6, 2005 11:38 AM
