Shifter pops out of 1st
Old Jul 6, 2005 | 10:49 AM
MisterMR's Avatar
Question Shifter pops out of 1st
Hopefully someone can help me out with this. Every now and then under not-so-hard acceleration in 1st gear, the shifter "pops" out of first gear as I start to shift into 2nd. It only happens on random occasions, and I can't replicate the conditions to make it happen on purpose, it just does it every once in a while. Anyone have any idea what this could be? I have a 2005 MR with around 5000 miles on it.
Old Jul 6, 2005 | 10:53 AM
DaWorstPlaya's Avatar
It happens to me too but only when hitting higher RPMs and you don't even need to be at WOT ... nothing to worry about.
DCSilvrEvo's Avatar
Sycro might be going out... My 5th gear popped out on the highway and I thought my clutch went out or something..
Old Jul 6, 2005 | 10:55 AM
MrMejia's Avatar
thats exactly right, your synchro mesh gears are wearing fast. DUDE!! you have a 2005 MR with 5k!!! WTF are you thinking?! poor car man...shame on you for beating it the way you do.
Old Jul 6, 2005 | 10:57 AM
If his synchro was going out he should hear grinding when he shifts .... for me its more like assisted shifting, I guess it could be because of the high rpms in the tranny and the fluid pressure building up due to heat, I might be completely off ...
Old Jul 6, 2005 | 11:01 AM
MrMejia's Avatar
well it coulf really be a combination of a lot of things. hey guy, If I were you I would definitely pull that tranny out and make a serious overhaul inspection. hmmm....did you install a short shifter?
Old Jul 6, 2005 | 11:06 AM
Greg K's Avatar
has nothing to do with synchros. you are likely a little late getting the clutch in, or a little early shifting to second. This is not really a big deal. Essentially you are partially pulling the car in to neutral without the clutch. In the short term it will have no real adverse effect, but I would work on the timing a bit to prevent premature wear of the dogs that engage the gears. I had a similar situation with this car until I got used to the engagement point of the clutch, (it's at a different place in the travel than I was used to). Good Luck.
Greg
Old Jul 6, 2005 | 11:07 AM
RayBaer's Avatar
Mine does the same thing too. Must be something with the MR 6 spd. I never thought twice about it. My 3rd gen Eclipse I had a couple years back did that too. Never had tranny probs. with it.
Old Jul 6, 2005 | 11:08 AM
Greg K's Avatar
that is not very good advice. I suggest reading up and having some idea of what goes on with a car before giving technical advice.
http://auto.howstuffworks.com/transmission.htm
Old Jul 6, 2005 | 11:09 AM
MrMejia's Avatar
yes , I'm a little high right now so you'll have to exuse me.
Erik@MIL.SPEC's Avatar
Mines done this maybe once, but that's it. Have 6000 miles and no problems.
Old Jul 6, 2005 | 11:11 AM
vrrrm...psss's Avatar
LOL
Old Jul 6, 2005 | 11:22 AM
MrMejia's Avatar
okAY THen HERES SOME GREAT ADVICE, how about not driving the EVO when you HigH.
Old Jul 6, 2005 | 11:30 AM
MisterMR's Avatar
Thumbs up
Thanks for the help fellas. I guess for now I won't worry about it and see if it's a timing issue... i'll pay a little more attention to my shifts. As for the amount of miles I have on the MR already, i know, it's a ton, but I've been travelling from Philly to DC and back for work every week, so that shiz really adds up quick!
Old Jul 6, 2005 | 11:38 AM
Spec'd's Avatar
I didn't hear any mention about the transmission oil being used or
if it has ever been changed.
tehSteve
Oct 17, 2010 02:39 PM
redlne8
20
Nov 17, 2006 11:22 AM
NonEvo
15
Aug 11, 2005 08:08 PM
plokivos
Jan 21, 2005 05:18 PM
SpecVSpeed
Aug 8, 2004 07:35 AM
