Car won't start but cranks!! help asap!
Old Dec 13, 2015 | 10:12 PM
RAC's Avatar
RAC
Originally Posted by 02modlanceroz
It really depends. A non start issue can be caused by a number of different things. Were you driving and the car randomly shut off and won't start? Or did you come out one day to start it and it wouldn't fire up?
It's was having weird issues days before.
It would idel form 1- 1 1/2 then cut off at times unless I was moving or pressing the gas to keep it from cutting out. For about a week
Then came from school one night and park it, next morning would not fire up.
Check all fuse possibilities and played with several relays the green ones and play ones, just change the spark plugs like a month ago.
It's been a week can't figure it out.
Old Dec 13, 2015 | 10:39 PM
02modlanceroz's Avatar
Do you have any engine codes present? Test to see if it's fuel that's your issue or spark.
If it's a fuel problem, I do know that the fuel relays were complete junk in the older Evo x. That's a good place to start. See if your fuel pump is even humming when you're in accessory or trying to start it
Old Dec 14, 2015 | 06:32 AM
twabtoxer's Avatar
Would a bad crank sensor cause this?
Old Dec 14, 2015 | 08:12 AM
RAC's Avatar
RAC
I'll take pic tonight of what's in there and check for humming.
Old Dec 14, 2015 | 08:13 AM
RAC's Avatar
RAC
I have read this can be the issue too. I'm also going to play with this idea tonight
Old Dec 15, 2015 | 05:40 PM
RAC's Avatar
RAC
Trying to go bya Auto zone to get a ecu reader to check codes.
So far a pic of relays.
Old Dec 16, 2015 | 04:31 PM
RAC's Avatar
RAC
Got a computer code reader!
So now I got the following codes.
-P1871 x 2 & U0100 x2
http://www.evoxservicemanual.co.uk/P...003800-22C.pdf
I guess I need to find a mechanic in North SD, Oceanside area.
Old Dec 16, 2015 | 06:03 PM
Sounds like you lost communication to the Ecu. Have you ever flashed the Ecu? Were you in the middle of flashing it prior to this issue?
Old Dec 17, 2015 | 08:19 AM
RAC's Avatar
RAC
No, not at all.
Old Dec 17, 2015 | 09:27 AM
Make sure all your connections are good on the Ecu, disconnect the battery for 15 min. Reconnect and see if the car will try and start
Old Dec 17, 2015 | 09:30 AM
P1871 - Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
Old Dec 18, 2015 | 09:31 AM
RAC's Avatar
RAC
Thank you, for you're research.
So the possibility is The relay or wire burn out.
Old Dec 18, 2015 | 01:23 PM
The U0100 is what worries me. That means the ECU has lost communication. That's why I was saying to try disconnecting he battery to see if that would resolve it. I doubt it will, but it's worth a shot. If the ECU went bad, I believe all manufactures have to warranty them for 8 years. With that code present. There's no way the car would start. Check all your wiring really good, make sure it's all intact and also check all your fuses again. Under the hood fuses and under the dash fuses
Old Nov 29, 2016 | 07:59 PM
EvilEvo_8's Avatar
Same Problem.
My Evo wont start, I've replaced my starter I bought from autozone, twice. The engine seems to want to turn over but smell burn from the starter, idk if it doesn't have much power, someone help , any suggestions.
Old Nov 29, 2016 | 08:57 PM
CrAnSwIcK's Avatar
if it cranks at all, there's nothing wrong with the starter...
my guess would be the clutch is not releasing, or the engine is seized.
