Interior Lighting
Old May 11, 2014 | 06:43 PM
JukEboXAuDiO's Avatar
Interior Lighting
HI guys,
Looking for some quick help. I am trying to wire some interior lighting to come on when the parking/headlights come on. Anyone know how I can do that? I need a 12V DC line. Is it best to go through the fuse in the engine compartment or is there a wire I can tap into?
Any help is great.
Thanks.
Old May 31, 2014 | 09:15 AM
CamShaft's Avatar
The best option would be to run a dedicated fused circuit to a relay and have the marker lights turn the relay on. You will need schematics and some knowledge of automotive electronics.
To find the proper fuse rating, find the load of the lights, IE) 80 watts/12v = 6.6amps , you will need a 10 amp fuse.
You can use the yellow wire coming out of the ETACS connector C-311. It is a 20 pin connector and the wire is in pin 10. This wire supplies your marker lamps. Use this as a signal to your relay.
TxFAkuma
Jul 20, 2016 02:02 PM
TxFAkuma
49
Jul 9, 2015 12:17 PM
costas_evo8
Sep 18, 2010 08:22 AM
NJ_evoIXgsr
Apr 19, 2009 04:26 PM
The.alibi
18
Jan 3, 2007 01:29 PM
