Radio and iterior lights dont turn on Help!!
after trying to wire my boost gauge i couldnt get it to work so i went to turn my key and my radio and interior lights and clock wont turn on but everything else works fine
you probably have a wire that was exposed and caused the fuse to burn out, as the above poster said. make sure your connections are covered correctly (electrical tape, heat shrink wrap, etc.)
Pulling the fuse out of that yellow contraption can be confusing at first. Pull the yellow thing straight up, it will come up about a 1/2 inch. Don't pull the yellow thing completely off.
GEt some needle nose pliers, and pull the fuse out of the yellow case by grabbing it, pulling, and gently twisting. It'll take a few tries, but it'll come out. You'll probably munch the old fuse, but who cares. You're replacing it!
Hope this helps.
Hope this helps.
ALEX9X
Dec 4, 2016 12:19 PM
heathc84
Nov 18, 2015 09:25 AM
