Help with doors unlocking
Old Dec 29, 2014 | 10:15 PM
jimbo74's Avatar
Veteran: Air Force
Ok, so when I got my 03 Lancer ES, to unlock all the other doors from driver's door, on the outside, you would turn the key clockwise a second time, after unlocking the driver's door.
Recently, this second unlock of all the doors, doesn't work.
If I open the driver's door, and then use the switch inside, all the doors lock and unlock just fine
Old Dec 30, 2014 | 12:08 AM
CrAnSwIcK's Avatar
switch is probably bad...
left - MR526931
right - MR526932
Old Dec 30, 2014 | 04:33 PM
jimbo74's Avatar
Veteran: Air Force
which switch is that?
this is what I found?
Old Dec 30, 2014 | 10:11 PM
CrAnSwIcK's Avatar
82053l
Old Jan 2, 2015 | 10:36 PM
jimbo74's Avatar
Veteran: Air Force
so is the part an actual electrical switch attached to the door lock cylinder or is it an assembly that has to be replaced as a whole big (read: expensive unit) ?
Old Jan 3, 2015 | 06:49 AM
CrAnSwIcK's Avatar
should be a switch that attaches to the lock cylinder similar to an ignition switch...
HimynameisWillzyx
Oct 19, 2011 11:23 AM
628
Apr 26, 2009 04:36 PM
kaonashi
Sep 19, 2007 09:30 AM
sekula
Nov 7, 2006 07:03 PM
