Using oil extractor to change cooling fluid
Old Jan 25, 2017 | 03:18 PM
pcguru2000's Avatar
I have to change my engine coolant and had the idea of not making a mess and using a fluid extractor tube/pump pushed in through the radiator cap opening on the top of the radiator, and suck out all the old fluid. (the extractor works great on the oil for another car and I clean the extractor when I'm done)
The questions is....
Can I do this with an extractor tube (it's about outer diameter 1/4") or is there going to be an obstruction from the radiator as I push the tube in? (i.e. is it a straight vertical shot to the bottom?)
The car is a Lancer DE 2009
Old Jan 25, 2017 | 03:20 PM
pcguru2000's Avatar
oil filter relocation
on a 2009 lancer de, I'm tired of getting under th car to change oil filters. Subaru has the oil filter on the top and I'd like to use a oil filter relocator.
Any recommendations?
Mounting locations for the filter holder?
Old Jan 26, 2017 | 02:08 PM
pcguru2000's Avatar
No one knows on an empty radiator from the top accessport if it's a clear shot all the way to the bottom???
Old Jan 27, 2017 | 03:49 AM
SYSTEMA's Avatar
If i remember right the the filler cap on the radiator is not directly attached to the radiator. A hose goes to the filler cap from the radiator.
//===(cap)====>(to engine)
|| _________
||[ radiator.... ]
\\[_________]
In theory you could follow the hose to get to the bottom but im not sure if you'll get it all. you may still need to open the petcock.
Old Jan 27, 2017 | 08:11 AM
Veronica's Avatar
Nope.
You could not snake a tube to the bottom.
Much easier to just use the radiator petcock.
inin36
16
Nov 10, 2017 06:07 PM
diablo82
Oct 25, 2006 03:54 PM
camdog17
Apr 14, 2004 09:22 AM
timzcat
Oct 28, 2003 08:45 PM
