Cold start, no crank, no start.
Old May 19, 2017 | 03:23 PM
Remik's Avatar
Hey guys I need help, I've been to two different mechanics and neither could get to the bottom of my problem. My 2011 GTS Lancer wont crank or start, it gives me an overheating warning even on cold starts. The rare times it does start, it will turn itself off after 15 mins of driving for overheating, even though it doesn't have any symptoms of over heating. So far we have changed the temp sensors, and the variable valve timing solenoid( it was making a wierd ticking sound when trying to start, long shot I know). The fans and radiator seem to be working fine, I'm starting to think it might be a problem with the comp. But I'm hoping someone might know whats going on before I pay to fix it.
Old Jul 19, 2017 | 09:34 PM
EdT's Avatar
EdT
Does it throw a OBD code ?
Normally the older Lancers had a crankshaft sensor problem, if oil sludge was built up near the sensor the car will just die or no start, the computer thinks there is something catastrophic wrong inside the crankshaft. The sensor is located inside an aluminum cap on the right side of the engine block that you can take off and clean or it should replaced with a newer improved design that will not collect sludge over time.
Might want to read this thread I started years ago ! ...LoL
https://www.evolutionm.net/forums/la...5-340-a-2.html
Old Jul 19, 2017 | 11:06 PM
4b11slayer's Avatar
You can start by checking for ignition signal at the starter. If your getting signal i would start with a starter replacement. The overheating i assume is not related tho.
heyythurr
Nov 3, 2014 11:52 AM
_des_
Mar 8, 2012 07:56 PM
hybrids14
Mar 19, 2007 01:06 PM
acidandroid
May 6, 2005 11:15 PM
cacrawfo
AEM EMS
Feb 8, 2004 08:13 PM
