Radio & Dome Light Issue
Old Jun 15, 2017 | 01:29 PM
Tomukas's Avatar
Hello, I own a 2003 Lancer Es and my Radio doesn't work at all doesn't even show a display and then my dome light doesn't work when I turn it on sometimes. I though it could of just been a blown fuse well at least for the Radio and when i go to look at the fuses turns out there is no fuses in them for the Radio nor the Dome Light . When I try to put the 10a fuse in correct spot it won't fit or go in at all. I would really appreciate if someone could help me fix this so i can play some snazzy tunes
Old Jun 16, 2017 | 01:14 PM
SilentCool's Avatar
Double check the base where the fuse connects or make sure you are purchasing the correct size?
Old Jun 16, 2017 | 01:42 PM
4G63_EVO's Avatar
Your referring to the fuse spot with the musical note that is blocked off, there should be another spot for the dome light/ radio look again, check all your fuses.
Also check your under hood fuses
Old Jun 20, 2017 | 10:10 PM
Moronicicon's Avatar
5 Year Member
In your fuse box (engine bay) is a yellow plastic square fuse holder that has two fuses. Those are the two "keep alive" fuses. The yellow holder may not be pushed down into place or both fuses are blown. That fuse holder is what is pushed in at the dealer when the car was new. The idea is, if the yellow box/holder is pulled up, the parasitic drain from the constant power items (dome lights, memory for the clock and radio) will not occur during storage and non use.
Tomukas
Lancer Troubleshooting
Nov 20, 2021 08:54 PM
Boston'sEvO-->8
May 3, 2021 04:18 PM
jzapatajr
17
Jun 2, 2020 06:44 PM
evojm27
May 3, 2010 06:25 PM
evo ippo
Nov 5, 2006 08:14 AM
