Will not rev when in gear
Old Oct 8, 2017 | 02:32 PM
GeeTeeS2008's Avatar
About 5 months ago, my wife and I bought an 08 GTS with 124k. It now has 132k. It was running and driving great until a few days ago when she had a fender bender. The hood, front bumper and drivers headlight were damaged, but the condenser and radiator seem unharmed. After the crash I tried to move the car, but it is limited to about 2200RPM. In park or neutral it revs up just fine. I get no CEL, and see no obvious signs of physical damage to any wires or sensors. Also, no sign of fluid leaks. I have spent hours upon hours searching the web, and have come up empty-handed. Any help would be very much appreciated! Thank you in Advance!
Old Oct 8, 2017 | 03:59 PM
4b11slayer's Avatar
You should scan it for trouble codes. Maybe be a pending code.
Old Oct 8, 2017 | 04:53 PM
Definitely a great idea, but I've ready tried, hoping to find something even without a service engine light on. My scanner reported no codes and said the MIL should be off. Thank you for the reply though!
Old Oct 9, 2017 | 06:32 AM
I just wanted to give a quick update: This morning I wanted to determine if the speedometer was working, just to see if the output was communicating that far. Since it's raining, I figured I would jack up the front wheels to try it, while staying in the garage. I found the speedo is working and seems accurate. I also found it would rev up seemingly normal. I then dropped the car down to pull it out of the garage to see if it still acted the same. In the small area of blacktop I have, I got it to about 2500RPM and decided to try it out on the road. All seems back to normal now, but I couldn't tell you why it's now acting well, or what the malfunction was to begin with... Any input would still be appreciated.
Sl33p3rEvo
Jul 11, 2018 09:24 AM
GeeTeeS2008
Lancer Troubleshooting
Oct 8, 2017 02:09 PM
s240
Oct 19, 2015 10:16 PM
heel2toe
25
May 8, 2014 07:28 AM
Frank120
Nov 7, 2010 04:27 PM
