09 GTS P0463 No fuel reading
Old Oct 15, 2017 | 10:15 PM
Basilikan's Avatar
First Mitsu dealer told me to replace the fuel gauge. After the repair the code didn't clear.
They told me to replace the instrument cluster.
Took it to a different Mitsubishi dealer where they told me to replace the fuel sensor itself. After that repair the code still didn't clear.
They then told me what the first Mitsubishi dealer told me that the instrument cluster itself was broken.
New instrument cluster, still no code clear.
Grounding issue? Wire shortage?
Any thoughts or ideas would be appreciated.
Also the car runs fine, no notable engine/performance issues.
Old Oct 16, 2017 | 08:51 AM
Veronica's Avatar
At this point you need to trace the wires from the fuel pump/sending unit and look for damage.
Old Oct 16, 2017 | 08:56 AM
Veronica's Avatar
If you have a wiring diagram you could also remove the connector at the pump/sending unit and ground the sending unit wire (directly to a good ground).
If the low fuel light/gauge go "Full" - the wiring and dash is good - it is the sending unit.
Why didn't the dealership do this?
[shrug]
PiNG
AEM EMS
Oct 25, 2006 05:54 PM
cbrtrx
Oct 3, 2006 02:29 PM
wudbevo
Lancer Engine Tech
11
Nov 24, 2005 08:51 AM
ex-honda
Nov 19, 2004 07:10 AM
schleppy
Jun 30, 2004 02:25 PM
