fog lights installation
Old Sep 11, 2002 | 08:21 AM
JeffCS's Avatar
Ok, I screwed them on . Now the problem is that I have absolutely no idea how to connect the electric. Someone want to take a quick foto of what they did as a guideline for me? Also, is there anywhere I can put the wires through the firewall without drilling a hole?
Old Sep 11, 2002 | 08:39 AM
DaTenshi's Avatar
well for the electric part i put the power wire to the battery becuase you have a switch to turn em on and off. I didnt want to drill a hole through thte firewall so i routed the wires behind the fender and above the wheel well. This works fine ive had my fog lights for 6-8 months now so its all good.~
Old Sep 11, 2002 | 08:42 AM
JeffCS's Avatar
but how do you wire it to the battery?! and what did you ground yours with? just any ol' screw or piece of metal?
Old Sep 11, 2002 | 08:45 AM
DaTenshi's Avatar
the power wire that you get with the lights just attatch it to the positive side of the battery and i grounded mine to a screw~
Old Sep 11, 2002 | 08:48 AM
JeffCS's Avatar
just put it on the top of the positive and put that red cover over it?
Old Sep 11, 2002 | 08:56 AM
Stumpy221's Avatar
best way is to unscrew the nut on the positive terminal on the battery, strip down the red wire of your fogs. Wrap the stripped wire around the screw then bolt back the nut to the positive side of the battery. its pretty simple.
im doin mine soon i jus need a place to put the fogs.
Old Sep 11, 2002 | 09:08 AM
JeffCS's Avatar
ok, i'll try that. thanks for the help
Old Sep 11, 2002 | 11:39 AM
Alchemist's Avatar
btw- this has been covered a few times before. Although NOBODY has given explicit directions on how they installed their lights. Lots of speculation and lots of "I had mine installed at a shop".
If you look on the FAR left of the engine compartment you'll find the little rubber stopper. Look behind the strut tower. see it now? you can wire through there if you want to and bring it over to the drivers side. Now you have to do a search on taking your dash apart to mount the switch. God, I hope you didn't get one of those big black boxes with the orange switch... I hate those.
There's also supposed to be another grommet if you follow the hood release cable from the lever through the firewall. You might have to take the plastic skid plates off. Carefully with a small screwdriver will do it. Another guy here says he wired his switch through there. I'll look when I buy another set of lights. I returned the first set. Like you, I didn't want to drill a hole in the firewall
Let us know how they turn out.
Old Sep 11, 2002 | 11:42 AM
Alchemist's Avatar
Oh- and how'd you get yours screwed on? Are they a single screw mounting style? the first set I bought was a double screw mounting and being late on a Thursday night I didn't want to even consider taking my bumper off
Old Sep 12, 2002 | 08:34 AM
JeffCS's Avatar
they were double screw mount, but not knowing where exactly the lights would point when powered up, I only have one screw on each right now, so I can situate it when the electricity is on.
reliablefr
18
Aug 30, 2012 11:46 PM
superflyevo
Midwest Region
13
Aug 11, 2010 12:40 PM
NismoSkylineGTR
Nov 3, 2002 01:08 AM
