Door Handles
Old Sep 13, 2002 | 12:34 AM
crusin_lancer's Avatar
Angry Door Handles
I'm not sure if anyone else is having this problem but it seems that all the interior door handles like to stick. They won't retract back in. Is this a problem where I need to replace them or something that WD-40 will fix. It's wierd because it happens to all the doors except the drivers side.
Old Sep 13, 2002 | 12:35 AM
uranium9v's Avatar
did you check your door springs? If you got aftermarket speakers in the door, chances are they poped the door springs out of place....get in there with a flathead and pop them back in..
Old Sep 13, 2002 | 12:37 AM
wags528's Avatar
wd-40 might work - - ur door latch is probably sticking - - thats why it won't let the door handle go back - - used to have that problem with my old car sometimes - - -oil it up good and see if works . . .?
Old Sep 13, 2002 | 12:40 AM
HobieKopek's Avatar
My spring completely fell out. Lucky bastards. Took me a long time to try compressing and fitting it back on the pegs in the dark. Even in the light the next day it took me a while. When that spring pops though your doors won't lock at all.
Old Sep 13, 2002 | 12:46 AM
couldn't be the spring popped out because my doors lock and I haven't even installed any aftermarket speakers either. I'll the WD-40. Thanks guys.
Old Sep 13, 2002 | 12:53 AM
HobieKopek's Avatar
You could try checking the cable that pulls the door open though...they can shift if the plastic can't hold them still or if they get pulled they can pop out of place. Just take it to the dealer though...make them figure it out.
UnholyMaggot
Jul 21, 2019 09:53 AM
deadstockkpomp
Jul 30, 2012 12:18 PM
loneracer05
Nov 17, 2011 12:23 PM
m4tt VIII
Feb 22, 2010 11:32 AM
Noob4life
Aug 20, 2006 10:11 AM
