How much inner fender remove when installing AEM CAI?
Old May 28, 2004 | 02:42 PM
JoeFriday's Avatar
How much of the inner fender wall do I have to remove to install the AEM Cold Air Intake?? Any help would be great.
Thanks
Old May 29, 2004 | 03:24 AM
jsfour's Avatar
i dont think you remove any.....
Old May 29, 2004 | 06:37 AM
yellance's Avatar
i only removed the bottom piece were the filter sits causeu have to bolt it on righ there that is about all i removed i did put it back cause aem suggested it is better cause direct heat from the ground is not good cause it is supposed to be cold air hence cold air intake. Best mod i have done so far.Remeber to reset ecu
Old May 29, 2004 | 01:55 PM
JoeFriday's Avatar
Alrighty then thanks!
I took of the neg on the battery before I started, and then put it back on when done. Waited for 10 minutes idling, so I hope that was reset. I mean no problems yet and I get that kick *** sound.
Old May 29, 2004 | 05:27 PM
yellance's Avatar
yep that is it yes it does sound awesome
Old May 29, 2004 | 05:30 PM
petey pab's Avatar
i also replaced the grille insert with mesh for better air flow
JJVeld
Mar 12, 2017 03:42 PM
David Buschur
Nov 2, 2015 10:03 AM
Jkor88
May 11, 2012 02:45 PM
biohazzard
10
Jan 11, 2009 01:40 PM
BigP436
Lancer Tranny/Drivetrain Tech
15
Sep 23, 2005 10:03 AM
