Help...my car wont start
For some reason my car will not start. I havent done anything to the ignition or the ECU. Ive already replaced my clutch switch. We tried to bypass the clutch switch as well but it worked for a couple of times but went back to dead. Everything else comes on( lights, radio, ect). I was told the ignition switch, starter, and even the battery. I dont think its the starter because I thought that the starter gives signs of failure before it goes out. Im at boiling piont with this car and have decided to sell it after I fix the problem. Please help.
I'm with Jason, check your fuses. Also check to make sure you haven't broken the circuit when you bypassed the clutch switch, or have created a short that is essentially showing the clutch is not engaged.
-- dave
-- dave
it was doing it before we tryed to bypass the clutch switch. its strange, I took it to my buddys dads shop and they couldnt find anything wrong and claened up the fuses and replaced them and slapped my fuse box a couple of times and it worked for a couple of days and it will still do the exact same thing...so if I give my fuse box a couple of slaps it will start.
Ted B
Jul 10, 2025 03:45 PM
wazzelby
Jul 18, 2015 05:46 PM
blowngasket
Jul 1, 2015 09:16 AM
