Loosening the top nut during spring installation
Old Aug 7, 2004 | 02:36 PM
FlashAngel's Avatar
My friend is having a hell of a time loosening the top nut on the top of the springs. He doesn't have any air tools does anyone have any suggestions on how to loosen it?? He said the rod is spinning everytime he tries to loosen the nut on the top.
Old Aug 7, 2004 | 02:39 PM
blaze_125's Avatar
If he doesn't have any air tools, he has to stick his hand through the spring and hold the strut. I hope he has a spring compressor. If he doesn't have a spring compressor, then forget my suggestion.
Old Aug 7, 2004 | 02:43 PM
FlashAngel's Avatar
Yes he has a spring compressor, only prob is brute strength is not going to hold the strut steady enough to loosen the bolt, he's tried vice grips with aluminum over the actual grips so as not to scratch it and the vice grips couldn't even hold it from spinning (Also it did NOT scratch the rod when he used the grips, the aluminum is softer than the chrome that the rod is made of therefore it did not scratch it.)
Old Aug 25, 2004 | 11:33 PM
ghostrider's Avatar
You NEED an impact gun to put enough torque to the bolt without spinning the center.
Old Aug 25, 2004 | 11:36 PM
lookslikeanevo's Avatar
like ghostrider said...impact wrench...
Old Aug 25, 2004 | 11:50 PM
liquidlancer's Avatar
craftsman pliers with the rubber covers ont e shock shaft work DO NOT MAR THE SHOCK SHAFT,
on the rear there is a flat spot for an open ended wrench on the top
or an impact wrench
Old Aug 25, 2004 | 11:52 PM
as long as your adding friction the the shaft it usualy doesent spin
get creative use one of those tomato jar openers my grandmother uses!!!! the rubbery disk things shove em in pliers and bam your done lol
Old Aug 26, 2004 | 12:04 AM
BlackLancer2k2's Avatar
safest bet is to take it somewhere where an impact gun is available.....see if any neighbors have one...
Old Aug 26, 2004 | 11:51 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I think a drill driver with a socket would do the trick too. If that fails, I used a cordless electric impact wrench, which has very little power but did the trick, and you can rent those for $20 at Home Depot or other places.
ChadS
11
Mar 25, 2014 09:39 PM
tcarretti
Aug 18, 2011 09:21 PM
undercoverpope
20
Jul 20, 2011 10:54 AM
Provost
18
Apr 8, 2009 09:14 PM
2002OZ
Lancer Troubleshooting
13
Oct 17, 2003 06:22 PM
