Question to everyone
Old Aug 8, 2004 | 12:50 AM
piero713's Avatar
ok this what happened i hiy a curve by mistake and i messed up my car. After this incident the car was limping up and down. I was wondering if anybody knows what is messed up. I've had my friends tell me it the axel, the sway bar, but all i know is that i can't even drive it without the car bouncing up and down. I would apprieciate any comments or suggestion that any one may have.
Old Aug 8, 2004 | 12:58 AM
nightrider's Avatar
you should check to see how bad the wheel is. if its not that then i dunno... but i hit a curb once and my car jumped alot due to bent rim.
Old Aug 8, 2004 | 06:05 AM
piero713's Avatar
I already repalced the rim and the car still jumps
Old Aug 8, 2004 | 06:35 AM
nine4surfah's Avatar
check your control arms too. they may had been damaged as well
Old Aug 8, 2004 | 06:45 AM
Iamkar33m's Avatar
check the control arms and the shock assembly.
Old Aug 8, 2004 | 07:24 PM
piero713's Avatar
How does the control arms look? I ask this because i have an idea but im not sure i'm right. thanks for the input though!
Old Aug 8, 2004 | 10:52 PM
piero713's Avatar
could it also the crossmember that messed up?
Old Aug 9, 2004 | 06:49 AM
HobieKopek's Avatar
Read the sticky in the How To/Install forums, moving to the troubleshooting forums.
Old Aug 26, 2004 | 07:59 PM
Wallesasuaz's Avatar
same thing happened to me....
I hit so hard i might have dislodged a motor mount. But ofcourse i was wrong..
It came to be the Lower Arm brace... it's what supports everything from your strut to the whole wheel assembly.
Mine bent so much, that my wheel was stuck onto the wheel well...
Old Aug 27, 2004 | 07:50 AM
piero713's Avatar
Yeah, I had to change my whole passenger side supension. Even though you change it it still feel different some how when driving. thanks though.
EvoNiner1986
South Region
Jan 22, 2009 03:37 PM
amoney
23
Feb 29, 2008 07:17 AM
khmerstyle
May 15, 2006 10:03 AM
LancerFreak
Lancer Troubleshooting
May 11, 2003 03:26 PM
