power loss
Old Oct 28, 2002 | 10:26 PM
CTS 1273's Avatar
Unhappy power loss
i bought my lancer and when it was new (under 500 mi) it would always bark second gear after about 600 or 700 mi it wont bark second gear any more and i also put on a short ram air intake and it still wont did this happen to anyone else or is there somthing wrong and how do i fix it thanks i herd that new plugs would help is this true
Old Oct 28, 2002 | 10:32 PM
pjal84's Avatar
Define "bark" and maybe we can make a diagnosis. If you only have 600/700 miles, you don't need new plugs I can tell you that right now.
Old Oct 28, 2002 | 10:56 PM
BlackLancer2k2's Avatar
if you drive a manual it could just be that your clutch plate isn't grabbing like it used too....but after 600 miles...seems unlikely, unless you ride your clutch hard
Old Oct 28, 2002 | 11:03 PM
agsmooth84's Avatar
bark Pronunciation Key (bärk)
n.
The harsh sound uttered by a dog.
A sound, such as a cough, that is similar to a dog's bark.
there you go pjal
Old Oct 28, 2002 | 11:05 PM
ryancb's Avatar
u gain any weight in the car i can do it still fine tru 2nd depending on pavement and if its wet i always can but when i added 3 subs it made it harder since the lancer has an open diff most of the torque / spin is on the right tire thats why it puls hard in a redline shift thru 2nd make sense? didnt think so. p.s. my car still does it after 5000 miles
Old Nov 4, 2002 | 09:25 AM
Rbrookstx's Avatar
1 thing to consider is that the tires are new and when tires are new they are more prone to "get off the ground". Well hard tires anyway, so if you want an easy chirp, buy some new tires. or just put a lil' armor all on them.
Old Nov 4, 2002 | 09:31 AM
HobieKopek's Avatar
I still don't know what you mean by "bark".
Old Nov 4, 2002 | 09:35 AM
bahamut's Avatar
bark as in 2nd gear chirping the tires? If so, it all depends on the driver messing with the clutch. People are know to do that in 2nd and 3rd gear for just a show of power.
stock tires are harder compound and have the tendency to slip.
Old Nov 4, 2002 | 09:46 AM
HobieKopek's Avatar
It's doable if you just mean chirping the tires. The new tire thing is true though. Low miles tires chirp a hell of a lot more than ones with a few grand on em. Your clutch and shifting techniques should have as much of an effect on it as the tires though.
joseph143
Jan 23, 2014 05:24 PM
fromWRXtoEVO
Nov 5, 2010 06:46 PM
Wicked White
51
May 22, 2010 02:11 PM
raced_EvoVIII
Mar 16, 2004 02:54 PM
