Breather filter..
Old Oct 30, 2002 | 09:41 AM
KMcW's Avatar
Breather filter..
Why does my engine studder when I have the breather filter on? Do I need to plug the hole in the intake?
Old Oct 30, 2002 | 09:49 AM
HobieKopek's Avatar
There should be a vaccuum hose somewhere if you're talking about what I think you are.
Old Oct 30, 2002 | 12:13 PM
pjal84's Avatar
If he's got a breather, the hole on the intake needs to be plugged and make sure the PCV valve is nice and sealed up to the breather. There's a weaker vacuum without the hole sealed and you're letting in uncounted air into the engine.
Old Oct 30, 2002 | 12:29 PM
HobieKopek's Avatar
OH! I'm a complete liar. For some reason I was still thinking intake. I've been especially dull as of late. Bear with me. Lotta stress at work.
Old Oct 30, 2002 | 03:35 PM
LBLancerDude's Avatar
what can you plug it with?
Old Oct 30, 2002 | 04:16 PM
pinoyesv6's Avatar
many breather filters come with lil caps that u put on the intake nipple. it looks like a gel cap.
like this
Old Nov 3, 2002 | 08:25 AM
02izzel's Avatar
k one quick question about that breather filter....you can only put it on if you have an intake? or can you juss put it on by itself? im trying to figure out the use for it. anything would help thanks!!
Old Nov 3, 2002 | 08:28 AM
bdavie's Avatar
you could put one on with out an intake, you just need to remove the hose that connects the pcv to the airbox and plug up the hole in the airbox.
Old Nov 3, 2002 | 08:34 AM
02izzel's Avatar
sweet! thanks! and what is the purpose for a breather filter?
Old Nov 3, 2002 | 03:48 PM
pjal84's Avatar
Catches blow by particles/oil and traps it in the filter. Oil stays in, air goes out. Stock setup returns the blow by mess into the intake tract to be burned in the next combustion cycle.
Old Nov 8, 2002 | 10:14 PM
Surfer_Sandman's Avatar
So is the benefit just a cleaner burn out of the engine?
Old Nov 8, 2002 | 10:50 PM
StreetLancer's Avatar
Dress up, and basically eliminates the need for that vacuum hose. Beyond that, I don't see any benefits. Anyone else?
Old Nov 14, 2002 | 12:42 AM
02izzel's Avatar
yah, pretty much dress up......theres really not a need for it, juss a different form of air goin in the engine. i can say that now,kus i didnt have a clue before and i acutally looked under my hood to see what was goin on. thanks for the help yall!! you learn something new everyday.
Old Nov 14, 2002 | 07:05 AM
andenbre's Avatar
The purpose of the hose is to burn hydrocarbons (unburned fuel) from ring blow by out of the crankcase so they dont go into the air. back in the 50s and 60s that same hose just vented under the car and blew oil all over the road. putting the breather filter on instead of the hose to the intake may help performance (very)slightly by keeping the throttle body and idle air valve clean and free from oily tar residue and helping to keep the intake and valves a little cleaner
Old Nov 14, 2002 | 07:22 AM
uranium9v's Avatar
you can always get 2 breathers and put one on both ends.....they don't serve that great of a function.....
