rsx-s in the winter..
Originally Posted by redevo8driver
are thinner tires better in the winter? you had said put thinner tires on the rsx..is that common knowledge?
Have you ever run on ice, and found that if you run on your toes you get grip, but if you flat foot you don't? Same concept.
Not sure if the knowledge is "common" outside of the areas which get a lot of snow. Tire Rack's recommended sizes tend to go a couple sizes narrower than OEM, so they seem to have figured it out.
Check out the skinny tires they use in the rally of Sweden.
http://www.7extrememotorsports.com/w..._206wrc_12.jpg
The worst decision I ever made was to be lazy/cheap and leave my ES100's on my RSXS for the winter.....it was quite amusing. I did get Yoko Avid V4s for this winter so I know it will be at least a lil bit better. The stock michilins weren't great either in the winter weather.
rsxtypesex
10
Sep 3, 2011 05:16 PM
