97 mitsubishi eclipse- need help engine problem
Old Apr 19, 2007 | 04:45 PM
eve8alex's Avatar
i have a friend with a mitsubishi eclipse 97 gst but has the jdm motor in it with a garrett turbo. his car shooting out tons of blue smoke aka burns alot of oil. he has taken this car to the same guy three time and the guy puts a head gasket in it every time and replace the trubo but it only fix the problem for maby a week. what could be the root cause to this problem?
Old Apr 19, 2007 | 05:33 PM
4-G-rim's Avatar
Has he done a compression test and leakdown test? This will determine if the piston rings are the fault
Valve stem seals may of gone bad too.
Old Apr 19, 2007 | 09:00 PM
fromWRXtoEVO's Avatar
What a POS mechanic .. why would he want to replace the head gasket 3 times? the corrective action and the discrepancies do not match.
Replacing the cylinder head 3 times is absolutely unheard unless you are running NOS or overheating the car. Have you guys done a compression test? have you guys inspected the turbo? is the turbo a used unit? it might have bad seals.
How is the power? how is the boost?, what is the temp?, it could be too many things including a valve job but your discrepanicies are very generic.
You need to spit the beans and give more details.
Carlos
Old Apr 19, 2007 | 09:02 PM
I also forgot, go to these website for more info:
www.dsmtalk.com
www.dsmtuners.com
www.dsmforums.com
Carlos
TSiAWD666's Avatar
Is the return oil line on the turbo kinked or otherwise blocked in some way?
Old Apr 19, 2007 | 09:17 PM
eve8alex's Avatar
sorry for the missing info, the guy throws parts at it and has no clue that is why im now looking into it. i don't have the car in yet but will do that as soon as i know the test done but thats what i was thinking. thanks for the help i was just looking for any as know problem.
2GDSM
Northeast Region
Dec 2, 2008 06:05 AM
3vo2005
Oct 27, 2006 11:21 AM
ANARKY
Apr 26, 2004 10:34 AM
olegpro01
Jun 27, 2003 03:49 AM
gsx95
May 21, 2003 04:24 PM
