GTR 7:38 'Ring time: Nissan cheats by using slicks?
Specifications
Engine
• VR-series twin-turbocharged 3.8-liter V6.
• 480 hp @ 6,800 rpm. 430 lb-ft torque @ 3,200–5,200 rpm.
• Dual overhead camshafts with variable intake-valve timing.
• Cast aluminum cylinder block with high-endurance/low-friction plasma-sprayed bores.
• IHI twin turbochargers, one per cylinder bank.
• Pressurized lubrication system with thermostatically controlled cooling.
Drivetrain
• ATTESA ET-S All-Wheel Drive (AWD) with independent rear-mounted transaxle integrating transmission, differential and AWD transfer case.
• Rigid, lightweight carbon-composite driveshaft between engine and transaxle.
• Electronic traction control plus 1.5-way mechanically locking rear differential.
• Vehicle Dynamics Control (VDC-R) with three driver-selectable settings: Normal (for daily driving, controls brakes and engine output), R-Mode (for ultimate performance, utilizes AWD torque distribution for additional vehicle stability) and Off (driver does not want the help of the system).
• Hill Start Assist prevents rollback when starting on an incline.
DisclaimerVDC-R cannot prevent accidents due to abrupt steering, carelessness, or dangerous driving techniques. Always drive safely.
Transmission
• 6-speed Dual Clutch Transmission with three driver-selectable modes: Normal (for maximum smoothness and efficiency), Snow (for gentler starting and shifting on slippery surfaces), and R mode (for maximum performance with fastest shifts).
• Fully automatic shifting or full sequential manual control via gearshift or steering wheel-mounted paddle shifters.
• Dual clutch design changes gears in less than 0.5 second (0.2 second in R mode).
• Downshift Rev Matching (DRM).
• Predictive pre-shift control (in R mode) based on throttle position, vehicle speed, braking and other information.
Wheels and Tires
• 20 x 9.5" (front) and 20 x 10.5" (rear) super-lightweight forged-aluminum wheels with Gunmetal Gray finish.
• Exclusively developed nitrogen-filled Bridgestone® RE070A high-capacity run-flat summer tires, 255/40R20 front and 285/35R20 rear.
• Tire Pressure Monitoring System (TPMS).
• Optional exclusively developed nitrogen-filled Dunlop® run-flat all-season tires, 255/40R20 front and 285/35R20 rear (includes Bright Silver wheels).
Brakes
• Brembo® 4-wheel disc brakes with 4-wheel Antilock Braking System (ABS), Brake Assist, Electronic Brakeforce Distribution and Preview Braking.
• Two-piece floating-rotor 15-inch front and rear discs with diamond-pattern internal ventilation.
• 6-piston front/4-piston rear monoblock calipers.
Steering
• Rack-and-pinion steering with vehicle-speed-sensitive power assist.
• 2.6 steering-wheel turns lock-to-lock.
Suspension
• 4-wheel independent suspension with Bilstein® DampTronic system with three driver-selectable modes: Normal/Sport (for automatic electronic control of damping), Comfort (for maximum ride comfort), and R mode (engages maximum damping rate for high-performance cornering).
• Electronically controlled variable-rate shock absorbers. High-accuracy progressive-rate coil springs.
• Front double-wishbone/rear multi-link configuration with aluminum members and rigid aluminum subframes.
• Hollow front and rear stabilizer bars.
Body/Chassis
• Exclusive Premium Midship platform with jig-welded hybrid unibody.
• Aluminum hood, trunk and door skins. Die-cast aluminum door structures.
• Carbon-reinforced front crossmember/radiator support.
Back to Top
Standard Features
Exterior
• Wide-beam headlights with High Intensity Discharge (HID) low beams.
• LED taillights and brake lights.
• Dual heated power mirrors.
• Flush-mounted aluminum door handles.
• Body-color rear spoiler with integrated center high-mounted stop light.
• UV-reducing tinted glass.
Audio/Navigation/Performance Monitor
• Digital Bose® audio system with AM/FM/in-dash 6-CD changer and 11 speakers including dual subwoofers.
• HDD Music Box system, including hard drive with 9.4 GB for audio storage.
• MP3, WMA and DVD audio capable. In-dash Compact Flash card reader.
• HDD-based GPS navigation with touch screen.
• Driver-configurable performance monitor, developed with Sony® Polyphony, with graphical readouts of vehicle data and driving data displayed on a total of 11 screens.
• 7-inch WVGA high-resolution color-LCD display for audio, navigation and performance monitor.
Interior
• Automatic Temperature Control (ATC).
• Electronic analog instrument cluster with multi-function trip computer and digital gear indicator.
• Power front windows with one-touch auto-up/down feature.
• Intelligent Key system with pushbutton start. Power door locks.
• Cruise control.
• Tilt/telescoping steering column.
• Bluetooth® Hands-free phone system with voice recognition.
Seating/Appointments
• Leather upholstered front seats with perforated Alcantara inserts.
• 8-way power front seats with entry/exit switch for rear-seat passengers.
• Driver-shaped bucket seat.
• Dual individual rear seats.
• Heated front seats.
• Leather-wrapped steering wheel and shift knob.
• Drilled aluminum pedals.
Safety/Security
• Nissan Advanced Air Bag System (AABS) with dual-stage supplemental front air bags, seat belt sensors and occupant-classification sensor.
• Driver and front-passenger side-impact supplemental air bags and roof-mounted curtain supplemental air bags.
• Front seat belts with pretensioners and load limiters.
• Nissan Vehicle Immobilizer System.
• Vehicle Security System.
Engine
Drivetrain
Transmission
Wheels and Tires
Brakes
Steering
Suspension
Body/Chassis
Back to Top
Standard Features
Exterior
Interior
• Cruise control.
Safety/Security
select the never seen vidz ... view the design stories
http://www.gtrnissan.com/index.en.us...mepage.Home.P2
Yes thats one fast car but the Evo X will do it in 7:34
And it will go from 0-170 mph in 10 sec. after minor upgrades
I like nissan but i am waiting to see how Evo X will respond to upgrades. 2 things will happen. Either I will stay with
or I will move on and forget about the whole Fast and furious crowd.
