Ft-86
Old Oct 27, 2009 | 04:19 AM
  #46
skyblas's Avatar
i will imagine this car to look great
after all
its the succession of the AE86
they need to make this right
or else they are screwed...
hopefully this car wont cost a bomb
but i still dont like the idea of a boxer engine, its just so not mod friendly...hopefully they have different engine variant to choose from, that would be great
Old Oct 27, 2009 | 10:14 AM
  #47
4Trouble's Avatar
Most likely it won't be anywhere near 2100lbs it was 25 years ago. Back then it was still a porker compared to CRX Si that came couple years after, which was somewhere in 1800lbs. Considering the same trend, the car is going to weigh about 3000-3200lbs at least.
It is most likely going to have a lot of hardware from WRX (such as brakes, 5 speed transmission etc) for the 'base' model which is most likely going to have the EJ20 in NA form, probably still revving to 8krpm and compression ratio close to 12.0:1, meaning it would be around 230-250bhp. I am thinking it would be no more than 2-3k cheaper compared to WRX even though usually joint project cars are very good value. There is some speculation that there will also be a turbocharged version, which I assume that it would have a lot of STI components and cost slightly over 30k, if it ever makes it to North American market. The JDM EJ20 is pretty stout, although it will still have issues like upgrading cams or changing spark plugs.
If there were a different engine to be put in, I don't see any other choice than the Toyota's 3.5 V6. If that happens, it is going to have the same problem as Nissan's VQ engine, questionable refinement at high rev and expensive mods.
Old Oct 27, 2009 | 12:53 PM
  #48
boondoc's Avatar
Can they do that though? Wouldn't it be smarter and more cost friendly to stick with the horizontal engine configuration and using the EZ30 or 36 flat 6's rather than configuring the car for V6's?
My beef is that know how Toyota does things if they do opt to put in a 6cyl they will probably market that model less for the tuner crowd and more for the "I want to feel young again" crowd . Rather than having it as an alternative to those who want more power out of the box. I hope they do what Hyundai did with the GenCoupe, make both offerings pretty much the same except for engine choice.
Old Oct 28, 2009 | 07:00 AM
  #49
GPTourer's Avatar
Now they're saying the Subaru version may come with AWD and turbo - in Japan, and that it might not come here at all, which is the opposite of what I'd heard earlier.
Old Oct 28, 2009 | 06:15 PM
  #50
PnutButterWolf's Avatar
Old Oct 28, 2009 | 06:27 PM
  #51
pwrofturbo's Avatar
Subaru render looks much better.
Old Oct 29, 2009 | 04:18 AM
  #52
boondoc's Avatar
Subie FTW!!!
Old Mar 30, 2010 | 01:28 AM
  #53
BriinumsBo's Avatar
my photochop :P
terps
23
Nov 3, 2011 05:22 AM
terps
Jan 28, 2011 11:02 AM
terps
Aug 26, 2010 02:16 PM
terps
Jan 22, 2010 12:13 PM
terps
12
Oct 19, 2009 07:07 PM
