lets play a game; whats wrong with this engine.
Old Apr 20, 2010 | 09:07 AM
malachi's Avatar
Originally Posted by jid2
There is no massive torque. It makes 260 ft-lbs peak. The curves look fine, they are just very low. I'd say you are running 14 lbs of boost on a stock turbo.
PS - this thread fails with no data/info at all. I believe the problem is that it needs more cowbell.
i think this may be the cause also! we will see what changes this will bring.
Originally Posted by gsrboi80
THIS
its stock, + 2.4 L stock turbo, stock IC/piping, stock exhaust. stock head, fuel, manifolds.
_______________________________________________
i think it may just be a tired bottom end.
Old Apr 20, 2010 | 09:24 AM
Ian0611's Avatar
I've got it!.... It's a diesel!!!!
Old Apr 20, 2010 | 09:48 AM
malachi's Avatar
you would think, but its not. thats what i dont get. it doesnt look like and evo sheet should look like
Old Apr 20, 2010 | 02:46 PM
project_skyline's Avatar
+1
What boost? Injectors are probably already maxed on it and so your boost limited.
Whats the compression?
This is like someone asking what the weather will in the next 5 days and not even give them a weather map or any information to figure it out. We are just guessing.
This thread=
Old Apr 20, 2010 | 08:09 PM
3gEclipseTurbo's Avatar
HAHAHAHA I know why hes not posting any real info on it.
I remember reading about this FAIL build over on another forum. He has a Stock 2.4l 4g64 3g eclipse block with a Stock evo8 head and evo8 turbo. The Stock block hes refering to is 9.5:1 4g64 which is bumped up to almost 11:1 after the head swap. Which probably lead to the rings failing from the high comp and boost, being the rings are the weakest link in the stock 4g64's. Oh an if i remember correctly hes only pushing 12psi.
Old Apr 20, 2010 | 10:26 PM
sprx19's Avatar
This thread should win biggest jackass of the year thread. You post a random graph, don't say what car or mods.....or data logs.....OR SYMPTOMS .....christ it could be ANYTHING........
Old Apr 20, 2010 | 11:49 PM
So 12 psi and stock 4g64 block? Wow...
Old Apr 21, 2010 | 05:01 AM
EvoSeanzie's Avatar
I still say its Corr Performance. They know their Civics, but I wouldn't let them touch my Evo, let alone my lawn mower.
Old Apr 21, 2010 | 09:45 AM
malachi's Avatar
that is somewhat the point. to get even the most random of ideas of what is going on.
and i said mods. everything stock but the 2.4. did you not read that?
Old Apr 21, 2010 | 09:47 AM
malachi's Avatar
no, i did the "tune" myself. and the reason i say "tune", is because all i did was get the knock out, and up the A/F. its not a real aggressive tune, and i even backed off some timming from stock map.
Old Apr 21, 2010 | 09:49 AM
malachi's Avatar
ummm no its not 12, actually right there i think its 15 PSI, and i have been running 17PSI, and this summer im going to 20.
the only problem with that is traction, there is none.
Old Apr 21, 2010 | 09:52 AM
malachi's Avatar
+1
This thread=
when i say stock, what do you think i mean? this is the evo forum, there for it would be stock evo injectors. trust me, THEY are not maxed out. and again, im not look at the power, im looking at how the curve falls off.
Old Apr 21, 2010 | 09:56 AM
malachi's Avatar
the only FAIL in here is YOU. what are you doing following me? are you gay or somthing?
and if you think that doing the DOHC head swap, jumps the compression up to 11:1, your the bigest dumbass of all. but then again if YOU HAD ACTUALLY DONE A HEAD SWAP, you would know what your are talking about, instead of talking out your ***!
and you dont remember correctlly cause your a dumbass. since you have nothing to add to this, or ANY forum on the headswap, all you can post is "FAIL".
you have nothing good to provide to this forum, so GTFO!
this is a forum, ask a question, get an answer. I purposefully made this thread exactly the way it is, to try and get different answers. To get an “OUTSIDE” the box response.
scheides's Avatar
EvoM Moderator
There's your problem. More boost, and tuning of the timing. Get the AFR's in teh low 11's, decent timing through peak torque (looks about right now, this will depend on the setup) and gently step by step up to 10-12° at 7k, and turn up the boost! 22-23psi peak!
Is this an evo8 or 9? 8's stock cams suck, so you might be about done with it. There may be nothing wrong with this map, except the tune (and arguably lack of mods LOL). Do your homework buddy
Old Apr 21, 2010 | 10:14 AM
I dont know who you think im am but i have a fully built 4g64 w/ evo head and a evo tranny swap.
So STFU. And sense your motor is already ****ed why are you turning up the boost? Thats just stupid. But then again if i had put a stock head on a stock block i would know so much more like you, and not even have 240whp.
