Tuning for DSM
Old May 25, 2010 | 08:00 PM
chrisff521's Avatar
Tuning for DSM
Im new to dsms and this website and right now Im a HONDA guy with an Integra and Im thinking of getting a dsm 95 GSX and the guy is telling me it has a aem ecu, a/f wideband and it needs a tune really bad because of a new turbo install. What is the best and cheapest route to go to get this tuned/flashed...whatever to get it run right.
Old May 25, 2010 | 10:24 PM
chrisff521's Avatar
Old May 27, 2010 | 01:35 PM
GPTourer's Avatar
Find a local tuner shop that is an authorized AEM installer and tuner.
Old May 29, 2010 | 08:14 AM
sherloc123's Avatar
There are shops not to horribly far from where you are. Go on dsmtalk or dsmtuners and look around at sponsors
Old May 30, 2010 | 05:18 AM
tsidrift1's Avatar
you live in new york dude. Go to Street Tuned Motorsports.
Old Jun 2, 2010 | 10:14 PM
GRNMCH's Avatar
AEM ECU is a stand alone system, it is very powerful but not for the newbies. You can sell it for around $800 and buy ECM Link and Stock ECU for around $700. Not only will it run better for everyday use, it will be much easier to tune yourself!
Or... you can keep the AEM and spend $100+/hour for someone else to tune it for you and it will NEVER run as smooth as ECM Link. A good tune will take a minimum of 2-3 hours.
BTW, I have run AEM since 2003, and while I like it for my own race cars, I still use ECM Link on my street cars.
Old Jun 3, 2010 | 09:06 AM
GPTourer's Avatar
Yeah, I think AEM is overkill for most DSMs. People like it because its a "standalone" so it sounds cool to say your car is running it, but I think with all the advances made with ECU link, flashed 98+ ECUs or the tried and true chipped EEPROM ECU + SAFC you don't need an AEM.
Unless this is some 800hp+ monster I'm thinking the AEM is overkill and not worth the hassle.
Old Jun 5, 2010 | 07:16 AM
alwaysboostin's Avatar
I switched to aem and wont ever go back my car runs so much smoother wheather my car has 300hp or 1000 it will have an aem only and i daily drive my car and it runs just as smooth if not smoother than when i had ecm link
Old Jun 6, 2010 | 08:55 AM
chrisff521's Avatar
I was just going to get an safc. Do I need to chip the ecu? I have a 95-Eprom. I didnt get a gsx I got a gst instead and its untuned also with a 95 e-prom ecu.
Old Jun 6, 2010 | 10:09 AM
TheBoz's Avatar
I am also running an AEM EMS and I love it. The amount of data you can get from the internal log is awesome. Also when you put int run 10* of timing it does just that. You dont have to run any funny transformations on the data.
Now with all that said, DSMLink is much better for someone who has no clue.
If you are going to do the AEM EMS, then hit the aempower forums. Start reading up on the threads about the ems.
Here is one that you will find very helpful:
http://forum.aempower.com/forum/inde...c,24045.0.html
Old Jun 6, 2010 | 10:14 AM
erald01's Avatar
dmstuners.com is the answer to dsm world
Old Jun 7, 2010 | 08:07 AM
GPTourer's Avatar
A keydiver chip is cheap and effective way to run bigger injectors without getting out of control with the S-AFC and keeping your timing in check. He can set a baseline of whatever injectors you are using so you only have to make small adjustments with the S-AFC. You also get things like a raised idle, stutterbox, no lift to shift, and some other goodies.
Old Jun 7, 2010 | 08:13 AM
chrisff521's Avatar
where can i get a chip from? ive searched google and only found one place...dsmchips.com but they dont sell it anymore...only upgrades for existing customers.
Old Jun 8, 2010 | 07:01 AM
GPTourer's Avatar
Huh. That's where I got mine. I didn't realize he had stopped. I'm guessing he's moved on to flashing '98-'99 ECU's (I can't remember if 97s could be flashed or not) You get the same results and those ECUs are easier to find and cheaper then the EEPROMs.
Old Jun 8, 2010 | 09:10 AM
GRNMCH's Avatar
SAFC is a terrible way to "control" fuel!!! It was fine in the late 90's and even maybe in the early 00's, but in 2010?
With all the cars running 9's on the ECM Link, the argument that it isn't "hard core" enough simply does not hold water. And if you are on a tight budget you can ether get a "light" version or a find a used one.
gsxeclipsepsi
Sep 16, 2014 02:47 AM
slos14
Jul 24, 2012 08:13 AM
4GMivec69
Oct 11, 2010 01:12 AM
BOSS_David
Northwest Region
39
May 30, 2010 10:27 PM
KyleTsi
Dec 30, 2009 08:13 AM
